How to use POST and PUT method using arduino with Ethernet Shield?
I'm using ASP.NET web server, it works well with Postman but doesn't work with my arduino. Please help me. Sorry my english is not good.
ASP.NET
[HttpGet]
        public Student GetStudent(string ID)
            StudentServerDbContext db = new StudentServerDbContext();
            var query = (from a in db.iSTUDENTs
                         where a.STUDENTID == ID
                         select a);
            var data = query.Select(x => new Student
                _08STATUS = x.iPERMISSION.STUDENTSTATUS,
            }).First();
            return data;
        public class Student
            public string _08STATUS { get; set; }
[HttpPost]
        public bool UpdateOut(string ID)
                        b.INOUTID = 0;
                        b.STUDENTID = ID;
                        b.OUTTIME = DateTime.Now;
                        b.INTIME = DateTime.Now;
                        db.iINOUTs.Add(b);
                    db.SaveChanges();
                    return true;
                return false;
        [HttpPut]
        public bool UpdateIn(string ID)
                    db.SaveChanges();
                    return true;
                return false;
.INO
      	client.println("GET /api/student/" + id + " HTTP/1.1");
     	 client.println("Host: 192.168.1.1");
     	 client.println();
client.find(":\"");
               client.readBytesUntil('\"', _status, sizeof(_status));
               myGLCD.print("Status: ", 170, 150);
               myGLCD.print(_status, 265, 150);
if(strcmp(_status,"IN") == 0){
                              client.println("POST /api/student/" + id + " HTTP/1.1");
      		client.println("Connection: close");
     		 client.println("Content-Type: application/x-www-form-urlencoded");
     		 client.println("Content-Length: 0");
      		client.println();
                  else {
     		client.println("PUT /api/student/" + id + " HTTP/1.1");
      		client.println();
A bit more information about what output you get and why you think that was wrong would help.
      		client.println();
In most cases a POST with no data doesn't make sense. I have no clue about that Microsoft stuff you use on the server so decide yourself. Same applies for PUT.
Do the requests reach the server? What tells the server log?
Post complete code and not excerpts. In my experience very often the error is in the part of the code that wasn't posted.
I tried to fix it but it still didn't work. Help me please.
It still works well with both Postman and Fiddler.
GET method works well.
ASP.NET
using System;
using System.Collections.Generic;
using System.Linq;
using System.Net;
using System.Net.Http;
using System.Web.Http;
using MODEL.EF;
using STUDENTSERVER.Models;
namespace STUDENTSERVER.Controllers.StudentController
    public class StudentController : ApiController
        private static readonly string[] VietnameseSigns = new string[]
            "aAeEoOuUiIdDyY",
            "áàạảãâấầậẩẫăắằặẳẵ",
            "ÁÀẠẢÃÂẤẦẬẨẪĂẮẰẶẲẴ",
            "éèẹẻẽêếềệểễ",
            "ÉÈẸẺẼÊẾỀỆỂỄ",
            "óòọỏõôốồộổỗơớờợởỡ",
            "ÓÒỌỎÕÔỐỒỘỔỖƠỚỜỢỞỠ",
            "úùụủũưứừựửữ",
            "ÚÙỤỦŨƯỨỪỰỬỮ",
            "íìịỉĩ",
            "ÍÌỊỈĨ",
            "đ",
            "Đ",
            "ýỳỵỷỹ",
            "ÝỲỴỶỸ"
        public static string RemoveSign4VietnameseString(string str)
            for (int i = 1; i < VietnameseSigns.Length; i++)
                for (int j = 0; j < VietnameseSigns[i].Length; j++)
                    str = str.Replace(VietnameseSigns[i][j], VietnameseSigns[0][i - 1]);
            return str;
        [HttpGet]
        public IEnumerable<iSTUDENT> GetStudentLists()
            var students = db.iSTUDENTs;
            return students.ToList();
        [HttpGet]
                         select a);
                _01APPLY = x.iPERMISSION.SENDAPPLY,
                _02NAME = x.STUDENTNAME,
                _03CLASS = x.CLASSID,
                _04SEX = x.STUDENTSEX,
                _05BIRTHDAY = x.STUDENTBIRTHDAY,
                _06ADDRESS = x.STUDENTADDRESS,
                _07PHONE = x.STUDENTPHONE,
                _09OUTTIME = x.iPERMISSION.STUDENTOUTTIME,
                _10INTIME = x.iPERMISSION.STUDENTINTIME
            }).First();
            data._02NAME = RemoveSign4VietnameseString(data._02NAME);
            data._04SEX = RemoveSign4VietnameseString(data._04SEX);
            data._06ADDRESS = RemoveSign4VietnameseString(data._06ADDRESS);
            return data;
            public bool _01APPLY { get; set; }
            public string _02NAME { get; set; }
            public string _03CLASS { get; set; }
            public string _04SEX { get; set;  }
            public string _05BIRTHDAY { get; set; }
            public string _06ADDRESS { get; set; }
            public string _07PHONE { get; set; }
            public string _09OUTTIME { get; set; }
            public string _10INTIME { get; set; }
        [HttpPost]
        public bool PostOut(StudentID studentid)
            string id = studentid.ID;
            if (!String.IsNullOrEmpty(id))
                try
                    iSTUDENT a = db.iSTUDENTs.FirstOrDefault(x => x.STUDENTID == id);
                    iINOUT b = new iINOUT();
                    var c = db.iINOUTs.OrderByDescending(x => x.INOUTID);
                    if (a.iPERMISSION.SENDAPPLY)
                        if (a.iPERMISSION.STUDENTSTATUS == "IN")
                            a.iPERMISSION.STUDENTSTATUS = "OUT";
                            a.iPERMISSION.STUDENTLOG = "OUT " + DateTime.Now.ToString();
                            a.iPERMISSION.STUDENTALLLOG = "OUT " + DateTime.Now.ToString() + "\n" + a.iPERMISSION.STUDENTALLLOG;
                            if (c.FirstOrDefault(x => x.STUDENTID == id) != null)
                                if (c.FirstOrDefault(x => x.STUDENTID == id).OUTTIME.Month == DateTime.Now.Month)
                                    a.iPERMISSION.STUDENTMONTHLOG = "OUT " + DateTime.Now.ToString() + "\n" + a.iPERMISSION.STUDENTMONTHLOG;
                                    a.iPERMISSION.STUDENTCOUNT++;
                                    a.iPERMISSION.STUDENTMONTHLOG = "OUT " + DateTime.Now.ToString();
                                    a.iPERMISSION.STUDENTCOUNT = 1;
                            b.INOUTID = 0;
                            b.STUDENTID = id;
                            db.iINOUTs.Add(b);
                        db.SaveChanges();
                        return true;
                    return false;
                catch
                    return false;
            return false;
        [HttpPut]
        public bool PutIn(StudentID studentid)
                try
                    iINOUT b = c.FirstOrDefault(x => x.STUDENTID == id);
                        if (a.iPERMISSION.STUDENTSTATUS == "OUT")
                            a.iPERMISSION.STUDENTSTATUS = "IN";
                            a.iPERMISSION.STUDENTLOG = "IN " + DateTime.Now.ToString();
                            a.iPERMISSION.STUDENTMONTHLOG = "IN " + DateTime.Now.ToString() + "\n" + a.iPERMISSION.STUDENTMONTHLOG;
                            a.iPERMISSION.STUDENTALLLOG = "IN " + DateTime.Now.ToString() + "\n" + a.iPERMISSION.STUDENTALLLOG;
                        db.SaveChanges();
                        return true;
                    return false;
                catch
                    return false;
            return false;
.INO
void getphoto(String id){
      client.setTimeout(1000);
      client.println("GET /home/getphoto/" + id + " HTTP/1.1");
      client.println();
void sendrequest(String id){
      client.println();
void updateout(String id){
      char outBuf[40];
      client.println("POST /api/student HTTP/1.1");
      client.println("Content-Type: application/json");
      sprintf(outBuf,"Content-Length: %u",9 + id.length());
      client.println(outBuf);
      client.println();
      client.println("{\"id\":\"4499164121146\"}");
void updatein(String id){
      char outBuf[40];
      client.println("PUT /api/student HTTP/1.1");
      client.println();
void  printRfid(){
     if (cardNum != '\0') {
                  resetscreen();
                  char endOfHeaders[] = "\r\n\r\n";
                  bool photo = false;
                  sendrequest(cardNum);
                  myGLCD.setColor(255, 255, 255);
                  // Skip HTTP headers
                  char header[256];
                  client.readBytesUntil(endOfHeaders, header, sizeof(header));
                  Serial.println(header);
                  client.find(endOfHeaders);
                  char _apply[6] = {0};
                  char _name[26] = {0}, _class[11] = {0}, _sex[4] = {0}, _birthday[11] = {0}, _address[21] = {0}, _phone[12] = {0}, _status[4] = {0}, _outtime[11] = {0}, _intime[11] = {0};
                  client.find(":");
                  client.readBytesUntil(',', _apply, sizeof(_apply));
                  if(strcmp(_apply,"true") == 0){
                              client.find(":\"");
                              client.readBytesUntil('\"', _name, sizeof(_name));
                              myGLCD.print(_name, 170, 25);
                              client.find(":\"");
                              client.readBytesUntil('\"', _class, sizeof(_class));
                              myGLCD.print(_class, 170, 50);
                              client.find(":\"");
                              client.readBytesUntil('\"', _sex, sizeof(_sex));
                              myGLCD.print(_sex, 170, 75);
                              client.find(":\"");
                              client.readBytesUntil('\"', _birthday, sizeof(_birthday));
                              myGLCD.print(_birthday, 220, 75);
                              client.find(":\"");
                              client.readBytesUntil('\"', _address, sizeof(_address));
                              myGLCD.print(_address, 170, 100);
                              client.find(":\"");
                              client.readBytesUntil('\"', _phone, sizeof(_phone));
                              myGLCD.print(_phone, 170, 125);
                              client.find(":\"");
                              myGLCD.print("Trang thai: ", 170, 150);
                              client.find(":\"");
                              client.readBytesUntil('\"', _outtime, sizeof(_outtime));
                              myGLCD.print("Tu: ", 170, 175);
                              myGLCD.print(_outtime, 220, 175);
                              client.find(":\"");
                              client.readBytesUntil('\"', _intime, sizeof(_intime));
                              myGLCD.print("Den: ", 170, 200);
                              myGLCD.print(_intime, 220, 200);
                                                // fix problem while waiting
                              while(client.available()){
                                    byte buffer;
                                    client.read(buffer, 1);
                              photo = true;
                              //digitalWrite(15, LOW);
                              digitalWrite(16, HIGH);
                              delay(100);
                              digitalWrite(15, HIGH);
                              digitalWrite(16, LOW);
                   else{
                              byte buffer;
                              myGLCD.print("Khong duoc giai quyet ra/vao cong.", CENTER, 105);
                              digitalWrite(14, HIGH);
                              delay(100);
                              digitalWrite(14, LOW);
                  if(photo){
                        getphoto(cardNum);
                        char buf[300];
                        unsigned int row = 0;
                        char bufx[100];
                        client.read(bufx, 66);
                              client.read(buf, 300);
                              myGLCD.drawRaw(10, 220-row, 150, 1, buf);
                              row++;
                              byte buffer;
                  if(strcmp(_status,"OUT") == 0){
                        updatein(cardNum);
                  else {
                        updateout(cardNum);
                  cardNum.remove(0);
Posman code
Host: localhost:55739
Cache-Control: no-cache
Postman-Token: 3d4e0dd4-ff55-6b29-c304-951b720082a5
{"id":"4499164121146"}
Fiddler code
PUT http://localhost:55739/api/student HTTP/1.1
Content-Length: 22
My code worked. The only thing I lack is "delay (1000);". I'm going crazy. Perhaps the POST and PUT functions need a delay to process. Thank you.
That might have fixed it for the moment but sooner or later it will reappear. You probably didn't handle the server response or something similar. As you didn't post complete code (that would compile) you're on your own to fix it correctly.
