How can I use a random function to generate a random message from given specific messages and display in an lcd , after every 2 seconds?
I'm using Arduino UNO
Thanks.
Thanks.
have a look at the arduino random documentation
horace:
Thanks for the quick reply,
I've already saw that, but it's with numbers, I don't know how to do it with text,
Here's the code I've tried out, this one is just to print in Serial Monitor, then I will do with LCD..
long randNumber;
randomSeed("A","B");
randNumber = random();
Serial.println(randNumber);
delay(50);
I get this error :
exit status 1
too many arguments to function 'void randomSeed(long unsigned int)'
Thanks..
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
randomSeed()takes one paramter - the seed to the pseudo random sequence
on a PC I tend to use time the arduino documentation recommends
randomSeed(analogRead(0));
Are you attempting to generate a sequence of random characters?
if so use the random() function to randomly access an array of characters 'a' to 'z'?
or generate a random number between 0 and 25 and add it to 'a'
Use the number returned by random() as the index to an array of phrases.
Something like
char * phrases[] = {"Phrase 1", "Phrase 2", "Phrase 3", "Phrase 4"};
randomSeed(analogRead(A0)); //attempt to make the sequence more random
byte index = random(0, 3); //get a number between 0 and 3
Serial.println(phrases[index]); //use it as the index to the array of phrases
UKHeliBob:
Use the number returned by random() as the index to an array of phrases.Something like
Hi, thanks for your reply, This is the exact code as I wanted and is working well in serial monitor, thank you so much,
but as I moved forward to transform into an led and button, its like as soon
as I will press the Push button, a random phrase should come to the LCD and stay until I leave the Button..
You can view the code below but the problem is , as soon as I press the button , a random phrase comes, but it keeps changing very fast, if I add a delay, little slow, I want it to just select one and then choose another one next time..
If you want I can shoot a video and upload to youtube,
the code is here....
const int buttonPin = 7;
int buttonState = 0;
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
///Serial.begin(115200);
pinMode(buttonPin, INPUT);
lcd.begin(16, 2);
pinMode(9, OUTPUT);
analogWrite(9, 50);
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH)
lcd.clear();
lcd.print("Press button to get a random phrase.");
else if (buttonState == LOW) {
byte index = random(0, 4); //get a number between 0 and 4 :D
lcd.setCursor(0, 0);
lcd.clear();
lcd.print(phrases[index]); //use it as the index to the array of phrases
Thanks!!
The continuous call to the lcd.clear() is causing the issue.
What you need to do is only check if the button is high or low when the button changes.
if (last_buttonState != buttonState)
last_buttonState = buttonState;
lcd.clear();
lcd.clear();
get it?
adwsystems:
The continuous call to the lcd.clear() is causing the issue.What you need to do is only check if the button is high or low when the button changes.
lcd.clear();
lcd.clear();
get it?
Hi , thanks for your reply, I get the concept clearly, but I didn't get the code.
I replaced the void loop and I get this follwing error...
'last_buttonState' was not declared in this scope
What am I doing wrong ?
Thanks..
nityoday:
You added a variable to the program without declaring it. I provided a code snippet to fix your problem. You need to provide the rest. If you want someone else to do all the work, that costs money.
adwsystems:
I am sorry, but I am new to coding and arduino and I am unable to understand.
Thank you.
@nityoday You sent me a PM saying, amongst other things
People are asking money
There is no need to pay anyone to write the program. You can do it yourself and people here will help, but only if you help yourself too.
Post the latest version of your program that you have written and the full text of any error messages. We can then give advice as to how you can fix it and you will learn something.
Alright,
UKHeliBob:
There is no need to pay anyone to write the program. You can do it yourself and people here will help, but only if you help yourself too.Post the latest version of your program that you have written and the full text of any error messages. We can then give advice as to how you can fix it and you will learn something.
Here is the code that I've been trying :
lcd.begin(16, 2);
pinMode(9, OUTPUT);
analogWrite(9,50);
lcd.clear();
lcd.clear();
Here's the error :
Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\SONY\Documents\Arduino\sketch_may17b\sketch_may17b.ino: In function 'void loop()':
sketch_may17b:20: error: 'last_buttonState' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
That "Snippet" provided by adwsystems
is replaced in my original code after void loop's second line...
I understood the concept that it should be the last button state , high / low.. however, I don't understand the code, basically, last_buttonState and that Exclamation mark! in his/her code..
The modified code of yours, that I modified and added lcd, push button, and IF/ELSE statements is here (I've already posted too )
lcd.begin(16, 2);
pinMode(9, OUTPUT);
analogWrite(9, 50);
lcd.clear();
lcd.clear();
Thank you.
This is one of those rare times when the error is quite literal, the variable last_buttonState is not delcared.
First, you need to declare last_buttonState just like you did buttonState.
Then you need to read on if...else statements and comparison operators, including not equal to
You have some comments, but should have more. I will add some for you.
if (last_buttonState != buttonState) // is this button state not equal to the last button state
last_buttonState = buttonState; // record current button state as last
if (buttonState == HIGH) // is current button state HIGH
lcd.clear();
else if (buttonState == LOW) // is current button state low
lcd.clear();
As I mentioned, you need to stop clearing the lcd if you want to stop the flickering. The information on the display only need to be updated when the button get pressed. Before you determine the state of the button, you need to determine if the state has changed (this is what I added).
adwsystems:
This is one of those rare times when the error is quite literal, the variable last_buttonState is not delcared.First, you need to declare last_buttonState just like you did buttonState.
lcd.clear();
lcd.clear();
Okay so what CURRENT code is,
int last_buttonState = LOW;
lcd.begin(16, 2);
pinMode(9, OUTPUT);
analogWrite(9,50);
lcd.clear();
lcd.clear();
The project is working fine expect what I can see is when Button is not pressed, I can see "Random Phrase (?) " and the "Press button" too both swapping very very fast...
When button is pressed, I succesfully see a normal Phrase selected randomly..
But
sometimes LCD goes crazy
with thousands of characters scrolling !
Sorry for deleting last answer as there were some illogical errors which were reapired now.
Thank you.
A switch does not go from 1 to 0 and 0 to 1, it bounces causing the Arduino to see 01010001010011111.
Between the ill placed }} at the end of the sketch, add a delay (50 to 200 should do fine). This will cause the Arduino to wait for the switch to settle on a value.
adwsystems:
A switch does not go from 1 to 0 and 0 to 1, it bounces causing the Arduino to see 01010001010011111.Between the ill placed }} at the end of the sketch, add a delay (50 to 200 should do fine). This will cause the Arduino to wait for the switch to settle on a value.
I've added a delay, LCD is showing Phrase (?) for some 5 seconds, then it shows Press button and then Phrase (?) real fast, like [SOS] Mode.
Last part of the code
delay(200);
And what is Karma ? I mean what happens if I add Karma to you ?
And what shall I do now for that LCD ?
also i can send a video, but how to send ?
Does it only display Phrase (?) while the button is pressed?
Not actually a problem, but the comment (or the code) is wrong. index will get a value between 0 and 3. In fact it better NOT get a value of 4 because your phrases are numbered 0, 1, 2 and 3 and there is no number 4
adwsystems:
Yes, only while button is pressed. There must be a problem of code because when button isnt pressed, We can see both prashe number and Press Button to... swapping very very fast.. We may have to add some delays or INTERRUPTS maybe ?
UKHeliBob:
Alright, thanks for improving, I thought they are numbered from 1 to 4.. These small errors can really help improving.
There should be no need to add delay()s and certainly no need to use an interrupt.
How exactly is the button wired ?
My advice would be to use INPUT_PULLUP in the pinMode() for the button to activate the built in pullup resistor. This will ensure that the input is held HIGH. Wire the pushbutton to take the input to GND when the button is pressed. That way the input will not be floating and possibly picking up stray inputs.
