Hi, everyone, I am trying to use the sketch (sendSMS) to send a message to my phone. But as the results shows, my phone didn't receive it. Do anybody know how to send an SMS by using this sketch or using AT command? Thanks in advance!
11:40:17.100 -> SMS Messages Sender
11:40:24.845 -> NB initialized
11:40:24.845 -> Enter a mobile number: +4407762311049
11:40:45.409 -> Now, enter SMS content: SENDING
11:41:11.497 ->
11:41:11.497 -> Message:
11:41:11.497 -> 313131
11:44:11.518 ->
SMS sender
This sketch, for the MKR NB 1500 board, sends an SMS message
you enter in the serial monitor. Connect your Arduino with the
SIM card, open the serial monitor, and wait for
the "READY" message to appear in the monitor. Next, type a
message to send and press "return". Make sure the serial
monitor is set to send a newline when you press return.
Circuit:
* MKR NB 1500 board
* Antenna
* SIM card that can send SMS
created 25 Feb 2012
by Tom Igoe
// Include the NB library
#include <MKRNB.h>
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[] = SECRET_PINNUMBER;
// initialize the library instance
NB nbAccess;
NB_SMS sms;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("SMS Messages Sender");
// connection state
bool connected = false;
// Start NB module
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while (!connected) {
if (nbAccess.begin(PINNUMBER) == NB_READY) {
connected = true;
Serial.println("Not connected");
Serial.println("NB initialized");
Serial.print("Enter a mobile number: ");
char remoteNum[20]; // telephone number to send SMS
readSerial(remoteNum);
Serial.println(remoteNum);
// SMS text
Serial.print("Now, enter SMS content: ");
char txtMsg[200];
readSerial(txtMsg);
Serial.println("SENDING");
Serial.println("Message:");
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNum);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result[]) {
int i = 0;
while (1) {
while (Serial.available() > 0) {
char inChar = Serial.read();
if (inChar == '\n') {
result[i] = '\0';
Serial.flush();
return 0;
if (inChar != '\r') {
result[i] = inChar;
i++;
I tried to use AT+command to realize this function, the problem is when i am using AT+CGSM, after typing in my destination address and , I input the message I want to send and , I failed here. No response from my modem.
I'm throwing this out since no one has replied. I am using a different cellular modem, but in order to send the message, a Crtl+Z is used. So with my hardware, once I enter the phone number and receive the > response, I enter the message, then Ctrl+Z to send. This does not work with the serial monitor in the Arduino IDE. I connect using TeraTerm and it works fine.
