How to use Serial Communication - but NOT with the TX and RX pins
Hi all,
I'm new to this forum and this is my first question.
I am using an Arduino Nano and due to physical space constraints I can only connect my bluetooth module to the board using the 6 ICSP programming pins. I understand that they are connected to pins 11,12,13, Vcc, Ground and RESET.
So what I'm asking if I can initialise Serial Communication between my bluetooth(connected to smartphone) and the Arduino Nano by using pins 11 and 12.
I don't know how to do this as the serial.begin command doesn't take pins as an input so I don't know how to change it from the default TX, RX pins to 11 and 12.
Thanks all
Delta_G:
https://www.arduino.cc/en/Reference/SoftwareSerial
With this library you just chose any two pins on your Arduino to communicate via serial with your HC-05.
Those pins will be Rx and Tx.
ARDUINO DIRECTION OF DATA HC-05
Tx -----> Rx
Rx <----- Tx
The ICSP pins on an arduino are not for regular serial communications - it is a different thing entirely
