Oh, I thought you wanted ESP code.
Here is some code i wrote for the Due that does the serial thing
#include <uMT.h>
#include <Wire.h>
#include "TFMini.h"
#include <Servo.h>
#include <SimpleDHT.h>
// scl pin 5, sda pin 4, vcc 3.3
// temperature, pressure, altitude, sealevelpressure
#define BMP085_ADDRESS 0x77 // I2C address of BMP085
#define BMP_Interval 65503
const unsigned char OSS = 0; // Oversampling Setting
// Calibration values
int ac1;
int ac2;
int ac3;
unsigned int ac4;
unsigned int ac5;
unsigned int ac6;
int b1;
int b2;
int mb;
int mc;
int md;
// b5 is calculated in bmp085GetTemperature(...), this variable is also used in bmp085GetPressure(...)
// so ...Temperature(...) must be called before ...Pressure(...).
long b5;
const String sSeperator = " ";
Servo ServoLIDAR;
#define ServoLIDARPosit 1450
#define byteServo_LIDAR_Pin 11
String sA = "";
//X Axis servo
Servo X_Axis;
#define byteXaxisServoPin 9
#define iX_Posit90 1538 //using writeMicroseconds
int iX_HowMuch = iX_Posit90;
//Y Axis servo
Servo Y_Axis;
#define byteYaxisServoPin 10
#define iY_Posit90 1492 //using writeMicroseconds
int iY_HowMuch = iY_Posit90;
TFMini tfmini;
// unsigned long lPreviousLIDAR_SequenceMillis = 0;
#define lLIDAR_SequenceInterval 50 // milliseconds
// 25mS is 40Hz
// 33mS ~30Hz
// 50mS 20Hz
// bool bBlankLIDAR = false;
#define byteUnoDataReady 22
// unsigned long lCurrentMillis = 0;
//microwave motion detector= iMW
#define MWM_PINin 34
#define MWM_PINout 36
// #define lLEDRateInterval 125 //milliseconds, second
// unsigned long lPreviousLED_BlinkMillis = 0;
// bool bLedOnOff = false;
String sMessageToSend;
String sPi;
// bool bRcveDone = false;
// for DHT11,
// VCC: 5V or 3V
// GND: GND
// DATA: 2
#define pinDHT11 2
SimpleDHT11 dht11(pinDHT11);
#define iDHT_Interval 60503
#define iDoVolts_Interval 45007
#define MINservo 1000
#define MAXservo 2000
#define SerialBaudRate 9600
#define Serial2BaudRate 115200
#define StringBufferSize 50
// bool bTask2Started = false;
#define EVENT_A 0x0001
TaskId_t iEvtID_A;
#define EVENT_B 0x0002
TaskId_t iEvtID_B;
#define EVENT_C 0x0003
TaskId_t iEvtID_C;
#define EVENT_D 0x0004
TaskId_t iEvtID_D;
#define EVENT_E 0x0005
TaskId_t iEvtID_E;
#define EVENT_F 0x0006
TaskId_t iEvtID_F;
#define SEM_ID_01 1 // Semaphore id
#define SEM_ID_02 2 // Semaphore id
#define SEM_ID_03 3 // Semaphore id
#define SEM_ID_04 4 // Semaphore id
// #define TIMEOUT_A
Stream* stream2Ptr;
pinMode(40, OUTPUT);
digitalWrite( 40, LOW );
pinMode(byteUnoDataReady, OUTPUT);//setup interrupt pin as output
digitalWrite(byteUnoDataReady, LOW);//set state initial
Serial1.begin(TFMINI_BAUDRATE);
// Initialize the TFMini LIDAR
tfmini.begin(&Serial1);
// Initialize single measurement mode with external trigger
tfmini.setSingleScanMode();
Serial2.begin( Serial2BaudRate );
stream2Ptr = &Serial2;
pinMode(MWM_PINin, INPUT);
pinMode(MWM_PINout, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);//blink LED at pin 13
analogReadResolution( 12 );
ServoLIDAR.attach( byteServo_LIDAR_Pin, MINservo, MAXservo ); // attaches the servo pin to the servo object
ServoLIDAR.writeMicroseconds(ServoLIDARPosit);//sets initial posit
X_Axis.attach( byteXaxisServoPin, MINservo, MAXservo );
X_Axis.writeMicroseconds( iX_Posit90 );
Y_Axis.attach( byteYaxisServoPin, MINservo, MAXservo );
Y_Axis.writeMicroseconds( iY_Posit90 );
Serial.begin(SerialBaudRate);
// allocate a buffer in memory for these strings
sMessageToSend.reserve( StringBufferSize );
sPi.reserve( StringBufferSize );
Wire.begin();
bmp085Calibration();
ADC->ADC_MR |= 0x80; //set free running mode on ADC
REG_ADC_MR = (REG_ADC_MR & 0xFFF0FFFF) | 0x00020000; // adc start up value
// ADC->ADC_CHER = 0x80; //enable ADC on pin A0
Kernel.Kn_Start();
} // setup()
// if ( !bTask2Started )
Errno_t error;
TaskId_t fC_P;
// fCheck_Pressure
error = Kernel.Tk_CreateTask(fCheck_Pressure, fC_P);
if ( error != E_SUCCESS )
fKernalError( "fCheck_Pressure", error );
// bTask2Started = !bTask2Started;
Kernel.Tk_StartTask(fC_P);
// fCheck_TH
TaskId_t fC_TH;
error = Kernel.Tk_CreateTask(fCheck_TH, fC_TH);
fKernalError( "fCheck_TH", error );
Kernel.Tk_StartTask( fC_TH ) ;
// fCheckInputVoltage
TaskId_t fDoVolts;
error = Kernel.Tk_CreateTask( fCheckInputVoltage, fDoVolts );
fKernalError( "fCheckInputVoltage", error );
Kernel.Tk_StartTask( fDoVolts ) ;
// fDoLIDAR
TaskId_t fLIDAR;
error = Kernel.Tk_CreateTask( fDoLIDAR, fLIDAR );
fKernalError( "fDoLIDAR", error );
Kernel.Tk_StartTask( fLIDAR ) ;
// fReadSerial
error = Kernel.Tk_CreateTask( fReadSerial, iEvtID_A );
Kernel.Tk_StartTask( iEvtID_A );
// fDO_bRcveDone
error = Kernel.Tk_CreateTask( fDO_bRcveDone, iEvtID_B );
Kernel.Tk_StartTask( iEvtID_B );
// fTweakServoX
error = Kernel.Tk_CreateTask( fTweakServoX, iEvtID_C );
Kernel.Tk_StartTask( iEvtID_C );
// fTweakServoY
error = Kernel.Tk_CreateTask( fTweakServoY, iEvtID_D );
Kernel.Tk_StartTask( iEvtID_D );
// fLIDAR_ServoAspectChange
error = Kernel.Tk_CreateTask( fLIDAR_ServoAspectChange, iEvtID_E );
Kernel.Sm_Release( SEM_ID_02 ); // release a single SEMAPHORE token
Kernel.Sm_Release( SEM_ID_03 );
Kernel.Tk_StartTask( iEvtID_E );
// fSendOut_SEMAPHORE
error = Kernel.Tk_CreateTask( fSendOut_SEMAPHORE, iEvtID_F );
Kernel.Sm_Release( SEM_ID_01 ); // release a single SEMAPHORE token
Kernel.Tk_StartTask( iEvtID_F );
for ( ;; )
if ( stream2Ptr->available() >= 1 )
// if (Serial2.available() >= 1)
Kernel.Ev_Send(iEvtID_A, EVENT_A);
Kernel.Sm_Claim(SEM_ID_04, uMT_WAIT); // stop and wait for serial to be received and release of SEMAPHORE token
} // serial available
Kernel.Tk_Yield();
} // loop
void fKernalError(String sTask, unsigned error)
Serial.print( " Tk_CreateTask(): " + sTask + " Failure! - returned " );
Serial.println( error );
Serial.flush();
Kernel.isr_Kn_FatalError();
} // void fKernalError()
// digitalWriteDirect / digitalReadDirect
// example: digitalWriteDirect(13, HIGH)
inline void digitalWriteDirect(int pin, boolean val)
if (val) g_APinDescription[pin].pPort -> PIO_SODR = g_APinDescription[pin].ulPin;
else g_APinDescription[pin].pPort -> PIO_CODR = g_APinDescription[pin].ulPin;
// example: digitalReadDirect(12)
inline int digitalReadDirect(int pin)
return !!(g_APinDescription[pin].pPort -> PIO_PDSR & g_APinDescription[pin].ulPin);
void fDoLIDAR()
long iLIDAR_Distance = 0;
long iLIDAR_Strength = 0;
String sMsgToSend;
String s_cm = "cm ";
sMsgToSend.reserve( 16 );
while (1)
Kernel.Tm_WakeupAfter( lLIDAR_SequenceInterval ); // Wake up after ... milliseconds
Kernel.Sm_Claim(SEM_ID_02, uMT_WAIT); // // stop lidar servo
Kernel.Sm_Claim(SEM_ID_03, uMT_WAIT); // stop x y servo
// if ( !bBlankLIDAR )
if ( digitalReadDirect( MWM_PINin ) )
// if ( digitalRead( MWM_PINin ) == 1 )
digitalWriteDirect( MWM_PINout, HIGH );
tfmini.externalTrigger();
iLIDAR_Distance = tfmini.getDistance();
iLIDAR_Strength = tfmini.getRecentSignalStrength();
if (iLIDAR_Distance < 600)
// Serial.println( "TF Mini distance " + String(iLIDAR_Distance) + s_cm + " strength " + String(iLIDAR_Strength ) );
// Serial.flush();
sMsgToSend.concat( s_cm + String(iLIDAR_Distance) + " " + String(iLIDAR_Strength ) );
Kernel.Sm_Claim(SEM_ID_01, uMT_WAIT); // // claim a single SEMAPHORE token
sMessageToSend = sMsgToSend;
Kernel.Ev_Send(iEvtID_F, EVENT_F); // trigger fSendOut_SEMAPHORE + consume a single SEMAPHORE token
sMsgToSend = "";
digitalWriteDirect( MWM_PINout, LOW );
// bmp085 functions
// Calculate pressure given up
// calibration values must be known
// b5 is also required so bmp085GetTemperature(...) must be called first.
// Value returned will be pressure in units of Pa.
long bmp085GetPressure(unsigned long up)
long x1, x2, x3, b3, b6, p;
unsigned long b4, b7;
b6 = b5 - 4000;
// Calculate B3
x1 = (b2 * (b6 * b6) >> 12) >> 11;
x2 = (ac2 * b6) >> 11;
x3 = x1 + x2;
b3 = (((((long)ac1) * 4 + x3) << OSS) + 2) >> 2;
// Calculate B4
x1 = (ac3 * b6) >> 13;
x2 = (b1 * ((b6 * b6) >> 12)) >> 16;
x3 = ((x1 + x2) + 2) >> 2;
b4 = (ac4 * (unsigned long)(x3 + 32768)) >> 15;
b7 = ((unsigned long)(up - b3) * (50000 >> OSS));
if (b7 < 0x80000000)
p = (b7 << 1) / b4;
p = (b7 / b4) << 1;
x1 = (p >> 8) * (p >> 8);
x1 = (x1 * 3038) >> 16;
x2 = (-7357 * p) >> 16;
p += (x1 + x2 + 3791) >> 4;
return p;
// Calculate temperature given ut.
// Value returned will be in units of 0.1 deg C
short bmp085GetTemperature(unsigned int ut)
long x1, x2;
x1 = (((long)ut - (long)ac6) * (long)ac5) >> 15;
x2 = ((long)mc << 11) / (x1 + md);
b5 = x1 + x2;
return ((b5 + 8) >> 4);
// Read the uncompensated pressure value
unsigned long bmp085ReadUP()
unsigned char msb, lsb, xlsb;
unsigned long up = 0;
// Write 0x34+(OSS<<6) into register 0xF4
// Request a pressure reading w/ oversampling setting
Wire.beginTransmission(BMP085_ADDRESS);
Wire.write(0xF4);
Wire.write(0x4 + (OSS << 6));
Wire.endTransmission();
// Wait for conversion, delay time dependent on OSS
// delay(2 + (3 << OSS));
Kernel.Tm_WakeupAfter( 2 + (3 << OSS) );
// Read register 0xF6 (MSB), 0xF7 (LSB), and 0xF8 (XLSB)
Wire.write(0xF6);
Wire.requestFrom(BMP085_ADDRESS, 3);
// Wait for data to become available
while (Wire.available() < 3)
msb = Wire.read();
lsb = Wire.read();
xlsb = Wire.read();
up = (((unsigned long) msb << 16) | ((unsigned long) lsb << 8) | (unsigned long) xlsb) >> (8 - OSS);
return up;
// Read the uncompensated temperature value
unsigned int bmp085ReadUT()
unsigned int ut;
// Write 0x2E into Register 0xF4
// This requests a temperature reading
Wire.write(0xF4);
Wire.write(0x2E);
// Wait at least 4.5ms
Kernel.Tm_WakeupAfter( 5 );
// delay(5);
// Read two bytes from registers 0xF6 and 0xF7
ut = bmp085ReadInt(0xF6);
return ut;
// Stores all of the bmp085's calibration values into global variables
// Calibration values are required to calculate temp and pressure
// This function should be called at the beginning of the program
void bmp085Calibration()
ac1 = bmp085ReadInt(0xAA);
ac2 = bmp085ReadInt(0xAC);
ac3 = bmp085ReadInt(0xAE);
ac4 = bmp085ReadInt(0xB0);
ac5 = bmp085ReadInt(0xB2);
ac6 = bmp085ReadInt(0xB4);
b1 = bmp085ReadInt(0xB6);
b2 = bmp085ReadInt(0xB8);
mb = bmp085ReadInt(0xBA);
mc = bmp085ReadInt(0xBC);
md = bmp085ReadInt(0xBE);
// Read 2 bytes from the BMP085
// First byte will be from 'address'
// Second byte will be from 'address'+1
int bmp085ReadInt(unsigned char address)
unsigned char msb, lsb;
Wire.write(address);
Wire.requestFrom(BMP085_ADDRESS, 2);
while (Wire.available() < 2);
msb = Wire.read();
lsb = Wire.read();
return (int) msb << 8 | lsb;
// Read 1 byte from the BMP085 at 'address'
char bmp085Read(unsigned char address)
unsigned char data;
Wire.requestFrom(BMP085_ADDRESS, 1);
while (!Wire.available())
return Wire.read();
void fCheck_Pressure()
Errno_t error;
// TimerId_t TmId;
String sMsgToSend;
sMsgToSend.reserve( StringBufferSize );
short bmp_temperature;
long bmp_pressure;
// float bmp_altitude;
//Serial.println( "do fCheck_Pressure" );
//Serial.flush();
while (1)
error = Kernel.Tm_WakeupAfter( BMP_Interval ); // Wake up after ... seconds
if (error != E_SUCCESS)
Serial.print(F(" WakeupAfter(): Tm_WakeupAfter() Failure! - returned "));
Serial.print((unsigned)error);
Serial.flush();
if ( digitalReadDirect( MWM_PINin ) == 0 )
sMsgToSend = "Pa ";
// Serial.println( "do fCheck_Pressure3" );
// Serial.flush();
bmp_temperature = bmp085GetTemperature(bmp085ReadUT());
bmp_pressure = bmp085GetPressure(bmp085ReadUP());
// sMsgToSend.concat( String(bmp_temperature) + sSeperator );
sMsgToSend.concat( String(bmp_pressure) + sSeperator );
// sMsgToSend.concat( String(bmp_altitude) + sSeperator );
// Serial.println( sMsgToSend );
// Serial.flush();
sMsgToSend = "";
// // bTask2Started = false;
void fCheck_TH()
// TimerId_t TmId1;
String sMsgToSend;
byte temperature = 0;
byte humidity = 0;
String sTH = "TH ";
while (1)
Kernel.Tm_WakeupAfter( iDHT_Interval ); // Wake up after ... seconds
dht11.read(&temperature, &humidity, NULL);
sMsgToSend = sTH;
sMsgToSend.concat( String(temperature) + sSeperator + String(humidity) );
// Serial.flush();
sMsgToSend = "";
} // while (1)
void fDO_bRcveDone()
String sAspectCng = "AspectCng";
String s_gX = "gX";
String s_gY = "gY";
Event_t eventoutB;
while (1)
Kernel.Ev_Receive(EVENT_B, uMT_ANY, &eventoutB);
digitalWriteDirect( 40, HIGH );
sPi.replace( "/", " " );
// sPi.trim();
// Serial.println(sPi + " bRcveDone" );
// Serial.flush();
if (sPi.substring(0, 9) == sAspectCng)
// Serial.println(sPi + " rcvd" );
sA = sPi.substring(9);
Kernel.Ev_Send(iEvtID_E, EVENT_E);
// Serial.println("AspectString " + sA );
// Serial.flush();
// Serial.println( sPi.substring(0, 2) );
if ( sPi.substring(0, 2) == s_gX )
// Serial.println(sPi);
// Serial.flush();
// stop lidar if lidar has token do not wait for freed token skip torque attempt
if ( Kernel.Sm_Claim(SEM_ID_03, uMT_NOWAIT) != E_WOULD_BLOCK )
iX_HowMuch = sPi.substring(3).toInt();
Kernel.Ev_Send(iEvtID_C, EVENT_C);
if ( sPi.substring(0, 2) == s_gY )
// Serial.flush();
iY_HowMuch = sPi.substring(3).toInt();
Kernel.Ev_Send(iEvtID_D, EVENT_D);
sPi = "";
digitalWriteDirect( 40, LOW );
void fReadSerial()
Event_t eventoutA;
char OneChar;
while (1)
// Event_t eventoutA;
Kernel.Ev_Receive(EVENT_A, uMT_ANY, &eventoutA);
while ( stream2Ptr->available() )
OneChar = stream2Ptr->read();
if ( (OneChar != '\n') )
//Serial.println(sPi);
sPi.concat( OneChar );
// Serial.println(sPi + " char" );
// Serial.flush();
} // if ( (OneChar != '\n') )
Kernel.Ev_Send(iEvtID_B, EVENT_B); // trigger fDO_bRcveDone
// bRcveDone = true;
// Serial.println( "bRcveDone set true" );
Serial.flush();
} // if ( (chrOne != '\n') ) else
} // while ( Serial2.available() )
Kernel.Sm_Release( SEM_ID_04); // release serial avaible trigger in loop
} // while (1)
1000 u sec to 2000 u sec limit = 90 degrees of travel +/-45 deg
1K = 45 to 2K = 135
void fTweakServoX()
Event_t eventoutC;
while (1)
Kernel.Ev_Receive(EVENT_C, uMT_ANY, &eventoutC);
X_Axis.writeMicroseconds( iX_HowMuch );
void fTweakServoY()
Event_t eventoutD;
while (1)
Kernel.Ev_Receive(EVENT_D, uMT_ANY, &eventoutD);
// Serial.println( "iY_HowMuch = " + String(iY_HowMuch) );
Y_Axis.writeMicroseconds( iY_HowMuch );
// send data to RPi
void fSendOut_SEMAPHORE()
Event_t eventoutF;
while (1)
Kernel.Ev_Receive(EVENT_F, uMT_ANY, &eventoutF);
// Serial.println("fSendOut_SEMAPHORE 0 " + sMessageToSend );
// Serial1.flush();
if ( sMessageToSend.length() >= 2 )
// Serial.println("fSendOut_SEMAPHORE 1 " + sMessageToSend );
// Serial.flush();
stream2Ptr->println( sMessageToSend );
digitalWrite(byteUnoDataReady, HIGH);//TRIGGER RPi3 to read data
// delay( .05 );
Kernel.Tm_WakeupAfter( 50 );
// Serial.println( sMessageToSend.length() );
// Serial.println("fSendOut_SEMAPHORE " + sMessageToSend );
// Serial.flush();
digitalWrite(byteUnoDataReady, LOW);//reset
sMessageToSend = "";
void fLIDAR_ServoAspectChange()
char fltBuff[32];
String sAspectComplete = "AspectComplete";
Event_t eventoutE;
String sMsgToSend;
while (1)
Kernel.Ev_Receive(EVENT_E, uMT_ANY, &eventoutE);
Kernel.Sm_Claim(SEM_ID_02, uMT_WAIT); // // claim a single SEMAPHORE token.
if ( sA.length() < 8 )
// bBlankLIDAR = true;
sA.toCharArray(fltBuff, sizeof(fltBuff));
float fltAspect = atof(fltBuff);
if (fltAspect > 900.00f)
// Serial.println("AspectString " + String(sA));
// Serial.flush();
ServoLIDAR.writeMicroseconds(fltAspect);
//delay(20);
// Serial.println( "AspectComplete " + sA );
// Serial.flush();
Serial.println("AspectString reject " + String(sA));
// Serial.println( "fLIDAR_ServoAspectChange " + sMessageToSend );
// Serial.flush();
sMsgToSend = sAspectComplete;
// bBlankLIDAR = false;
void fCheckInputVoltage()
String sMsgToSend;
String s_Volts = "VOLT ";
while (1)
Kernel.Tm_WakeupAfter( iDoVolts_Interval ); // Wake up after ... seconds
// Serial.println( "dovolt awake1" );
// Serial.flush();
sMsgToSend = s_Volts;
sMsgToSend.concat(String(analogRead(A0)));
// Serial.println( "fCheckInputVoltage" + sMsgToSend );
// Serial.flush();
sMsgToSend = "";
// Kernel.Sm_Release(SEM_ID_02);
The code I use for doing the serial port thing, I wrote originally for the Due and ported it to the ESP32.
