I am building my own version of a weather station and as I will be performing lots of data logging, I have configured a real time clock in both the external and internal units.
To ensure both ends are synchronised properly, I have written a function which sends a time string to the external unit, which is then received and using the "strstr" command, separated by finding a keyword (setT) and the results placed into a char array. This array is then used to update the external units RTC to be the same as the internal unit.
This all works properly and is fairly robust.
For information, the radio system is using the nRFL2410I.
However, it has occurred to me that I can use this code to control and do other things, so I have introduced an "if" statement, listing a second keyword.
This also works properly.
So here is my question.
You will see in the code, where I state, "// Do the whole thing again for second keyword search on the same received data", is there a smarter way of performing this?
void receiveData() {
char receivedDataString[32]; // Char string to store received data.
radio.startListening(); // Now, resume listening so we catch the next packets.
if (radio.available()) {
while (radio.available()) { // While there is data ready.
radio.read(&receivedDataString, sizeof(receivedDataString)); // Get the payload.
if (!debug == false) { // Serial print the received data to check consistency.
Serial.println(F("Time data received: "));
Serial.println(receivedDataString);
char keyword1[] = "setT"; // Set first keyword.
char* pointerToFoundData1 = strstr(receivedDataString, keyword1); // Check for first keyword.
if (pointerToFoundData1 != NULL) { // Was it found?
int positionInString = pointerToFoundData1 - receivedDataString;
strncpy(receivedDataString, &receivedDataString[positionInString + strlen(keyword1)], sizeof(receivedDataString));
const char delimiter[] = ","; // Ser delimiter.
char stString[10][5];
char* token = strtok(receivedDataString, delimiter); // Search for delimiter.
strncpy(stString[0], token, sizeof(stString[0]));
for (int i = 1; i < 10; i++) { // Do the same for each found delimiter.
token = strtok(NULL, delimiter);
strncpy(stString[i], token, sizeof(stString[i]));
for (int i = 0; i < 10; i++) { // Print out the results.
Serial.print("Set time string: ");
Serial.println(stString[i]);
// Data is received in this format: setT,h,21,m,44,D,20,M,09,Y,2020.
yearSet = atoi(stString[9]); // Update time setting variables.
monthSet = atoi(stString[7]);
daySet = atoi(stString[5]);
minSet = atoi(stString[3]);
hourSet = atoi(stString[1]);
// Use data to set DS3231 RTC module.
rtc.adjust(DateTime(yearSet, monthSet, daySet, hourSet, minSet, 0));// Send updated variables to RTC module.
DateTime now = rtc.now();
rtcArray[6] = now.year();
rtcArray[5] = now.month();
rtcArray[4] = now.day();
rtcArray[3] = now.dayOfTheWeek(); //returns 0-6 where 0 = Sunday.
rtcArray[2] = now.hour();
rtcArray[1] = now.minute();
rtcArray[0] = now.second();
char* dayOfTheWeek = (dayArray[rtcArray[3]]); // returns actual day of the week.
char* monthOfTheYear = (monthArray[rtcArray[5]]); // returns actual month of the year.
sprintf_P(TimeAndDateString, PSTR("%02d:%02d on %s %02d %s %02d"), rtcArray[2], rtcArray[1], dayOfTheWeek, rtcArray[4], monthOfTheYear, rtcArray[6]);
Serial.println("Time and Date have been set to: ");
Serial.println(TimeAndDateString);
else { Serial.println("No setT keyword found..."); }
// Do the whole thing again for second keyword search on the same received data.
char keyword2[] = "Blah";
char* pointerToFoundData2 = strstr(receivedDataString, keyword2);
if (pointerToFoundData2 != NULL) {
int positionInString = pointerToFoundData2 - receivedDataString;
strncpy(receivedDataString, &receivedDataString[positionInString + strlen(keyword2)], sizeof(receivedDataString));
char blahString[10][5];
strncpy(blahString[0], token, sizeof(blahString[0]));
strncpy(blahString[i], token, sizeof(blahString[i]));
Serial.println(blahString[i]);
else { Serial.println("No Blah keyword found..."); }
} // Close function.
