I am testing the Colored Light widget and I have the problem of using the 'on/off' switch to turn the leds off and on. What happens to me is that the leds are always on and I can't switch them off with the button. I can only switch them off if I set the slider to ZERO.
I have added some program lines in the sketch to use the switch but it gives me this error:
Start verifying
In file included from /home/builder/Arduino/libraries/fastled_3_6_0/src/FastLED.h:75,
from /tmp/2491589689/TestWS2812B_apr02a/TestWS2812B_apr02a.ino:18:
/home/builder/Arduino/libraries/fastled_3_6_0/src/fastspi.h:157:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
# pragma message "No hardware SPI pins defined. All SPI access will default to bitbanged output"
/tmp/2491589689/TestWS2812B_apr02a/TestWS2812B_apr02a.ino: In function 'void onLEDstripChange()':
/tmp/2491589689/TestWS2812B_apr02a/TestWS2812B_apr02a.ino:63:6: error: 'lEDtrip' was not declared in this scope
(lEDtrip, LOW)
/tmp/2491589689/TestWS2812B_apr02a/TestWS2812B_apr02a.ino:63:6: note: suggested alternative: 'lEDstrip'
(lEDtrip, LOW)
lEDstrip
Multiple libraries were found for "WiFi.h"
Used: /home/builder/.arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/WiFi
Not used: /home/builder/opt/libraries/wifiespat_1_4_3
Not used: /home/builder/opt/libraries/vega_wifinina_1_0_1
Not used: /home/builder/opt/libraries/wifinina_1_8_14
Not used: /home/builder/opt/libraries/nina_wi_fi_1_0_1
Not used: /home/builder/opt/libraries/seeed_arduino_rpcwifi_1_0_7
Not used: /home/builder/opt/libraries/wifi_1_2_7
Not used: /home/builder/opt/libraries/indhilib_3_0_5
Not used: /home/builder/opt/libraries/da16200_wi_fi_library_for_arduino_1_1_0
Multiple libraries were found for "WiFiClientSecure.h"
Used: /home/builder/.arduino15/packages/esp32/hardware/esp32/2.0.5/libraries/WiFiClientSecure
Error during build: exit status 1
(lEDtrip, LOW)
(lEDtrip, LOW)
lEDstrip
The sketch is this:
#include "arduino_secrets.h"
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/15de016d-ca87-4950-ba15-033e29aa2b3c
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
CloudColoredLight lEDstrip;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <FastLED.h>
#define NUM_LEDS 3
#define LED_PIN 2 // pin out signal
CRGB leds[NUM_LEDS];
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
Since LEDstrip is READ_WRITE variable, onLEDstripChange() is
executed every time a new value is received from IoT Cloud.
void onLEDstripChange() {
uint8_t r, g, b;
lEDstrip.getValue().getRGB(r, g, b);
for (int i = 0; i < NUM_LEDS; i++) {
leds[i] = CRGB(r, g, b);
//check if switch is on/off
if (lEDstrip.getSwitch()) {
else {
(lEDtrip, LOW)
FastLED.show();
Need help
EzioGi
