How to use the HC-06 without having it connected to the PC
Hi guys,
I have 2 motors connected to Arduino Leonardo and I have connected a BT HC-06. The code works perfectly when I fed to Arduino with the USB cable, but when I remove the cable and feed it with a 9v battery, makes the connection with the phone, but doesnt do anything. I'm working with Serial1 of Leonardo, but I dont know if this function only works if it connected to the PC or not but I want to use the Arduino and the HC-06 with my phone and without having connected to the PC. Thank you for your attention.
Greetings!
Step 1 is to use a real battery.
PaulS:
like? any recommendation
can i try with a 6v battery and 1.0Ah?
6v is the bottom limit, 7v is the minimum recommended. See the data sheets. You need either 5v applied directly, or 7>12v applied via the jack, i.e. through the regulators. If you must use a battery, you would be better off with 6x1.2v AA rechargeables.
Hi
The 9v battery doesn't has enough power to move two motors
