The UNO R4 WiFi features a VRTC pin, that is used to keep the onboard RTC running, even when the boards power supply is is cut off. In order to use this, apply a voltage in the range of 1.6 - 3.6 V to the VRTC pin.
RTC
A real-time clock (RTC) is used to measure the time, and is useful in any time-tracking applications.
Thanks for the explanation @JohnLincoln , and I can confirm this. As you stated the OFF pin will disable the board's power supply if powered via VIN. Shorting it while powered via USB will have no effect.
We will update the documentation with a note on this. Thank you!
Thank you @JohnLincoln for your prompt reply.
Where did you come by the detailed circuit diagram? I only saw the block diagrams on the Arduino datasheet ABX00087.
RTC
