How to use the PID Library to control 2 DC motor props
I've created a project where I have a pendulum hanging from a fixed point. The fixed point is a rotary incremental encoder (1024 pulses/revolution). At the bottom of the pendulum I have 2 DC motor fans facing opposite of each other. In order to swing the pendulum into an inverted position (at this time) I have one fan turning on and off using momentum to eventually swing itself up to the inverted position.
My question is, how do I set up the PID controller code to keep the fans working together to balance the fan straight up. With the encoder calibrated at 0 when it is hanging straight down, 512 clicks will get us to the 180 degree straight up point. So I have a variable named PosNum which represents the rotary encoder position.
Code so far:
#include <digitalWriteFast.h>
//ENCODER
// Quadrature encoders
// Left encoder
#define c_LeftEncoderInterrupt 4
#define c_LeftEncoderPinA 19    // Black Wire   //Blue and Bare wire to ground
#define c_LeftEncoderPinB 24    // White Wire
#define LeftEncoderIsReversed
volatile bool _LeftEncoderBSet;
volatile long PosNum = 0;
volatile long PosNum1 = 0;
volatile long PosNum2 = 0;
boolean Start = false;
//Pin Assignment for Motors
int dirA1 = 7; //direction of motor A
int dirA2 = 6; // direction of motor A
int speedA = 5;  // Throttle of motor A
int dirB1 = 2; //direction of motor B
int dirB2 = 3; // direction of motor B
int speedB = 4;  // Throttle of motor B
  //Motor A Pin Modes
  pinMode(dirA1,OUTPUT);
  digitalWrite(dirA1,HIGH);
  pinMode(dirA2, OUTPUT);
  digitalWrite(dirA2, LOW);
  pinMode(speedA,OUTPUT);
  analogWrite(speedA,0); //0-255 speed pwm
  //Motor B Pin Modes
  pinMode(dirB1,OUTPUT);
  digitalWrite(dirB1,HIGH);
  pinMode(dirB2, OUTPUT);
  digitalWrite(dirB2, LOW);
  pinMode(speedB,OUTPUT);
  analogWrite(speedB,0); //0-255 speed pwm
// Left encoder
  pinMode(c_LeftEncoderPinA, INPUT);      // sets pin A as input
  digitalWrite(c_LeftEncoderPinA, LOW);  // turn on pullup resistors
  pinMode(c_LeftEncoderPinB, INPUT);      // sets pin B as input
  digitalWrite(c_LeftEncoderPinB, LOW);  // turn on pullup resistors
  attachInterrupt(c_LeftEncoderInterrupt, HandleLeftMotorInterruptA, RISING);
int angle = 0;
  angle = map(PosNum,-1024,1024,-360,360);
  Serial.print(PosNum);
  Serial.print("\t");
  Serial.print(angle);
  Serial.print("\n");
if(Start == false)
     if(PosNum > PosNum2)
      analogWrite(speedA,255);
        analogWrite(speedA,0) ;
if(PosNum > 500)
      Start = true;
  // Interrupt service routines for the left motor's quadrature encoder
void HandleLeftMotorInterruptA()
  // Test transition; since the interrupt will only fire on 'rising' we don't need to read pin A
  _LeftEncoderBSet = digitalReadFast(c_LeftEncoderPinB);   // read the input pin
  // and adjust counter + if A leads B
  #ifdef LeftEncoderIsReversed
    PosNum2=PosNum1;
    PosNum1=PosNum;
    PosNum -= _LeftEncoderBSet ? -1 : +1;
  #else
    PosNum += _LeftEncoderBSet ? -1 : +1;
  #endif
I've looked at the arduino PID library and saw the functions. I'm not sure how I would implement these functions to have the 2 fans work together to hold the pendulum upright at the 512 pulse mark coming from the rotary encoder. I hope I provided enough information.
For the PID syntax: for PID()
PID(&Input, &Output, &Setpoint, Kp, Ki, Kd, Direction) *** Would I have 2 Outputs here?
PID(&Input, &Output, &Output2, &Setpoint, Kp, Ki, Kd, Direction) *** Like this?
Where is says Input, I'm assuming thats my PosNum variable from the encoder
My Setpoint would be set to 512.
Output would be speedA
Output2 would be speedB
Kp,Ki,Kd, is there a self tuning feature? Or do i have to hard code these values in via SetTunings()?
thanks for any advice.
So, why do you need 3 longs to hold the encoder position?
The encoder generates an interrupt, so the HandleLeftMotorInterruptA() function gets called. Hmmm... Seems to me that function should be called Fred().
if(Start == false)
Stop drinking and coding. Tools + Auto Format will sober this code up. Looks like a damned drunken sailor was in charge of the tab key.
If the error is negative, make one fan turn faster and the other slower. If the error is positive, do the same thing, but swap which motor speeds up and which slows down.
I can hard code values in but I want to learn how to use the PID library.
Dslethal:
OK. You have one input - the value from the encoder. You have one set point - the value that means the pendulum is upright. You get one output - how much to change to close the gap.
What you need to understand is what to apply that change to (the speed of both motors) and how to scale the needed change (experiment!). The change will require that one motor speed up and the other slow down. Which one speeds up and which one slows down is based on the sign of the error.
