How to use the SD folder's name here?
Hi all.
I'd like to operate the SD with subfolder, if set: String stringA = "Friday"; write a file into subfolder 'Friday', failed, how to fix please?
tested: 'writeFile(SD, "/Friday/Mondayhello.txt", "mmHello ");` works fine.
Thanks
Adam
#include "FS.h"
#include "SD.h"
#include "SPI.h"
String stringB = "Wednesday";
String stringC;
String StrWK[7] = {"Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"};
int writeFileButtonmark = 1;
  SDsetup();
  if (writeFileButtonmark == 1) {
    for (int i = 0; i < 7; i++) {
      if (stringA == StrWK[i]) {
        Serial.print("L36strArray["); Serial.print( i); Serial.print( "] =");
        Serial.println(StrWK[i]);
        writeFile(SD, "/StrWK[i]/Mondayhello.txt", "mmHello ");
        appendFile(SD, "/StrWK[i]/Mondayhello.txt", "mmWorld!\n");
        readFile(SD, "/StrWK[i]/Mondayhello.txt");
        writeFileButtonmark = 0;
void readFile(fs::FS & fs, const char * path) {
  Serial.printf("Reading file: %s\n", path);
  File file = fs.open(path);
  if (!file) {
    Serial.println("Failed to open file for reading");
    return;
  Serial.print("Read from file: ");
  while (file.available()) {
    Serial.write(file.read());
  file.close();
void writeFile(fs::FS & fs, const char * path, const char * message) {
  Serial.printf("Writing file: %s\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file) {
    Serial.println("Failed to open file for writing");
    return;
  if (file.print(message)) {
    Serial.println("File written");
    Serial.println("Write failed");
  file.close();
void appendFile(fs::FS & fs, const char * path, const char * message) {
  Serial.printf("Appending to file: %s\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file) {
    Serial.println("Failed to open file for appending");
    return;
    Serial.println("Message appended");
    Serial.println("Append failed");
  file.close();
void SDsetup() {
  if (!SD.begin()) {
    Serial.println("Card Mount Failed");
    return;
  uint8_t cardType = SD.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No SD card attached");
    return;
  Serial.print("SD Card Type: ");
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
  } else if (cardType == CARD_SD) {
    Serial.println("SDSC");
  } else if (cardType == CARD_SDHC) {
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  uint64_t cardSize = SD.cardSize() / (1024 * 1024);
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
OUTPUT:
D Card Type: SDHC
SD Card Size: 29818MB
L36strArray[4] =Friday
Writing file: /StrWK[i]/Mondayhello.txt
Appending to file: /StrWK[i]/Mondayhello.txt
Reading file: /StrWK[i]/Mondayhello.txt
You need to investigate the sprintf function.
And no doubt someone will be along shortly to tell you not to use Strings, for perfectly valid reasons.
Thank you.
It works.
