how to use the Serial.readString() to type something from the keyboard??
the code below does not work when i type for example green or red or yellow, can anybody suggest a solution??
int green=8;
int yellow = 7;
int red = 4;
int ledon = 0;
pinMode(8,OUTPUT);
pinMode(7,OUTPUT);
pinMode(4,OUTPUT);
Serial.println("please select");
String a ="";
if(Serial.available())
a = Serial.readString();
if (a=="green")
ledon = 1 ;
green = 8;
yellow= 7;
red = 4;
Serial.println("LED on");
if (a=="yellow")
ledon = 2;
green = 7;
yellow = 8;
red = 4;
if (a=="red")
ledon=1;
green = 4;
yellow= 7;
red = 8;
if (a=="off")
ledon = 0;
Serial.println("LED OFF");
if (ledon)
digitalWrite(green,HIGH);
digitalWrite(red,LOW);
digitalWrite(yellow,LOW);
digitalWrite(8,LOW);
digitalWrite(4,LOW);
digitalWrite(7,LOW);
How anyone can work with code laid out like that is beyond me
Here it is formatted much better using Aoto Format in the IDE and in code tags here to make it easier to copy to an editor
int green = 8;
int yellow = 7;
int red = 4;
int ledon = 0;
  pinMode(8, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(4, OUTPUT);
  String a = "";
  if (Serial.available())
    Serial.print(">");
    Serial.print(a);
    Serial.println("<");
    if (a == "green")
      ledon = 1 ;
      green = 8;
      yellow = 7;
      red = 4;
    if (a == "yellow")
      ledon = 2;
      green = 7;
      yellow = 8;
      red = 4;
    if (a == "red")
      ledon = 1;
      green = 4;
      yellow = 7;
      red = 8;
    if (a == "off")
      ledon = 0;
  if (ledon)
    digitalWrite(green, HIGH);
    digitalWrite(red, LOW);
    digitalWrite(yellow, LOW);
    digitalWrite(8, LOW);
    digitalWrite(4, LOW);
    digitalWrite(7, LOW);
Eagle eyed readers will note 3 lines of printing added for debugging purposes to see what readString() has returned
OP. What have you got the Line ending set to in the Serial monitor ?
What happens if you use a different setting for Line Ending ?
Does the output from the debugging lines change perhaps ?
