how to use time in if condition?
guys i simply want to know, can i use time to execute a command in if condition? I means to say that
if ( time==10second && sensor1 works ) { execute this statement }
tell me how would i use time==10 second here in if statement
How are you determining the time?
The usual method is using millis().
Something starts Starttime = millis()
Other things happen
If ((millis() - Starttime) == 10000) Do whatever
However, you may not be at this point at exactly the time 10000. It is better to use > rather than ==.
Weedpharma
weedpharma: If ((millis() - Starttime) == 10000) Do whatever
Actually, you need to use >= for accuracy.
that start thing...
Something starts if (something != oldSomeThing) // only happens once and that way starttime is not reset every scan starttime = millis()
oldSomeThing = something // next loop they will be equal
Other things happen
If ((millis() - Starttime) >= 10000) // shown with preferred use of >= Do whatever
bgautam1991:
I means to say that tell me how would i use time==10 second here in if statement
Your question isn’t clear. 10 seconds from when?
weedpharma:
Something starts
Other things happen
Do whatever
Weedpharma
Do whatever
thanks
Note the later reference to >=. This is important.
What happens if you program is doing something else at 10000? The next time it checks it could be 10001 so will not happen.
Weedpharma
weedpharma: Note the later reference to >=. This is important.
Weedpharma
If he did not understand the need to load millis(), once and just once, he will never get that far.
bgautam1991: thanks i got what you said
{ If ((millis() - Starttime) == 10000) Do whatever }
thanks
You almost "got what they said" ...
 If ( millis() - StartTime >= 10000 )
    Do whatever
There are two very good reasons why you should almost always use ">=" and rarely, if ever, use "==" when checking for elapsed time.
