How to use timer 16 bit timer to generate 16bit PWM on arduino mega
Hi, I'm currently using analogWrite to control DC motor speed, however, when applied PID to control more precise, the default 8bit PWM is not enough, so I need to use at least 10 bit PWM. As i'm using pin6, pin 7 and pin 8 on arduino mega 2560 to control, I believe that they are all on the same timer 4 and available of up to 16bit PWM. Are there any examples and tutorial online about this ? Thanks.
Excellent tutorial here: https://gammon.com.au/timers
CTC mode allows you to choose the bit depth.
I'd choose any 16 bit PWM mode and, if required, use ICR for the TOP value (0xFFFF). Then the 3 related PWM channels are free for use on a Mega. Please note that the duty cycle always ranges from 0 to TOP, not 0 to 100%.
