I want to read remote control key values using a timer of esp32. The timer should count the total value of high and low pulses so i can generate the same pulses on the other side. I tried using the given "repeat timer " in the example but it is not working the same as i expected. Is there any other way of using the timer to count pulses
Below code is not working
hw_timer_t * timer = NULL;
int ir_in = 15, value, arr[2000]={0}, arr1[2000]={0}, i;
unsigned int count, count1, flag = 0, flag1 = 0, no_pulse = 0, no_pulse1 = 0;
int dis_data();
pinMode (ir_in, INPUT);
timer = timerBegin(0, 80, true); // timer 0, MWDT clock period = 12.5 ns * TIMGn_Tx_WDT_CLK_PRESCALE -> 12.5 ns * 80 -> 1000 ns = 1 us, countUp
timerAttachInterrupt(timer, &onTimer, true); // edge (not level) triggered
timerAlarmWrite(timer, 1000, true); // 1000000 * 1 us = 1 s, autoreload true
timerAlarmEnable(timer); // enable
void onTimer(){
if(flag==1)
count1++;
// no_pulse=0;
// no_pulse1=0;
value = digitalRead(ir_in);
if (value == 0)
flag = 1;
while ((digitalRead(ir_in) == 0) && (flag == 1))
delayMicroseconds(1);
count++;
arr[no_pulse++] = count;
count = 0;
while ((digitalRead(ir_in) == 1) && (flag == 1))
count++;
arr1[no_pulse1++] = count;
count = 0;
flag = 0;
flag1 = 1;
if((count1>1000)&& (flag1==1))
for (i = 1; i <= no_pulse; i++)
Serial.print("arr-");
Serial.println(arr[i]);
for (i = 1; i <= no_pulse1; i++)
Serial.print("arr1-");
Serial.println(arr1[i]);
flag1=0;
count1=0;
no_pulse=0;
no_pulse1=0;
Below snippet of pi code that i want to use in arduino to count remote pulses.
READ:-
LED1 = 0;
TON_bit = 0;
delay_ms(100);
TON_bit = 1;
while((no_pulse < total_pulse)&& (time_over == 0))
while((IR_IN == 1) && (time_over == 0) );
TON_bit = 0;
TON_bit = 1;
TMR1 = 0;
while((IR_IN == 0)&& (time_over ==0));
irdata[no_pulse++] = (TMR1>>8)&0xff;
irdata[no_pulse++] = TMR1&0xff;
TON_bit = 0;
TON_bit = 1;
TMR1 = 0;
while((IR_IN == 1)&& (time_over ==0));
LED1 = 1;
delay_ms(2000);
