how to use toggle switch
my arduino is pro micro and i wanna install small toggle switch
on the board
i made wire at vcc to switch and i made another wire from gnd to pin 8 and made another wire from where pin 8 and gnd is conected to aniother head of toggle switch
but when i turn on the toggle switch it works but when i turn off the switch there is no lights on
i wanna install toggle switch and i dont know how to make it
can anyone help me?
On the Switch :
connect pin 1 or 3 to GND
connect pin 2 to pin 8 on the Arduino
On the Arduino set the pinMode(8, INPUT_PULLUP);
Read the switch in your code, it will go between HIGH and LOW when you activate the switch.
mike-bear:
Please draw an adequately detailed diagram of your configuration. Is pin 8 being used as an output pin? And if it is used as an output pin, then better not connect pin 8 to gnd.
Welcome to the forum.
Please read http://forum.arduino.cc/index.php/topic,148850.0.html.
What sort of toggle switch?
Do you know what each terminal on the switch is for?
Can you please post a picture of your project so we can see your component layout?
Thanks.. Tom.. :slight_smile:
@mike-bear
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
i installed toggle switch without resistor, i wanna know what will be happen if i dont use resistor on board and use toggle switch and is 10k resistor good to use or not?
If wired correctly, no resistor is needed.
pin 8 to pin 2 and connect to one pin of toggle switch
pin 3 to ping GND and connect to another of pin of toggle switch
@mike-bear, please study and follow this tutorial to learn how to use a switch and to learn how to use it without the need for an external resistor:
After that, if you still have questions, come back here with detailed and specific questions and we'll help you out.
On a toggle switch you have 3 pins
I will call these from left to right T1, T2 and T3
Connect T1 to 5V
Connect T3 to GND
Connect T2 to Pin 8
in your code, read pin 8 and it will be high(5V) OR low(GND - 0V)
Yet another duplicate merged
Two ways to wire a SPDT (Single Pole Double Throw) switch to an Arduino input.
groundFungus:
But the first way is risky, you'll possibly get much more signal bounce while the pin is floating, perhaps
picking up nearby crosstalk.
I'd suggest always using a pullup, physical or internal.
I would always use the second way, but the first one was mentioned so I wanted to show it schematically.
With the second way, an external resistor, for stronger pull-up, may be required if the switch is on long wires to overcome noise.
