I have a ttp226 touch sensor module lying with me.(the photo of touch module is attached ). I want to use it so that I can control relays and in turn control AC loads.
By simply connecting the module with 5V DC, I get momentary output as long as I touch it. But for using it as a switch I am looking for an Arduino code that would control it's 8 channels such that once I touch a single channel, the output is high, again when I touch it, it becomes low. I want this to happen with all the 8 channels so that 8 loads would be controlled through it.
Is it possible using an Arduino code ?
Please help me if it's possible. Any help would be greatly appreciated.
You can do that! Which Arduino?
Which pins for inputs from the touch board?
Which pins for outputs to the relay board?
Post a link for the relay board, BTW, I don't trust those little blue relays for switching 230VAC, but...
I want to use Arduino uno sir. The touch module has8 output pins, you can use all of them
outsider:
