I'm on a project that need to use the ultrassonico sensor and IR sensor. When I turn my robot must operate using the ultrassonic sensor.
But I can also choose to use the remote, so it will work with IR. However, by submitting the code, the ultrasonic no longer works ...
Click the MODIFY button on the upper right of the window,
Highlight only the code,
Click the "#" CODE TAGS button,
Click the SAVE button on the lower left ,
In the future please use the "#" CODE TAGS toolbutton when you post code.
Hello, the ultrassonic sensor worked, but is getting lost, stopping all the time.
And the infrared sensor does not trigger.
I followed his example, and tried changing, but still does not work as expected.
What might be happening?
Does the control() function is wrong?
Follows the code with the changes.
#include <Servo.h>
#include <SPI.h>
#include <IRremote.h>
float num = 0;
Servo servo1;
Servo servo2;
Servo servo3;
int cm;
int st;
int trig = 6;
int echo = 7;
long microseconds;
/* =================== Declaração do IR ===================*/
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
float armazenavalor;
irrecv.enableIRIn(); // Start the receiver
st=2;
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
servo1.attach(8);
servo2.attach(9);
servo3.attach(10);
servo1.write(110);
servo2.write(70);
servo3.write(100);
delay(5000);
static boolean IRMode = true; // Start in IR Remote mode
if (irrecv.decode(&results)) {
armazenavalor = results.value;
Serial.println(armazenavalor, HEX);
if (armazenavalor == 0xFF9867){
IRMode = false;
else if (armazenavalor == 0xFFA25D){
IRMode = true;
else if (IRMode == true){
controle();
if (!IRMode) {
sensor();
long microsecondsToCentimeters(long microseconds) {
return microseconds / 29 / 2;
void sensor(){
long duration, cm;
digitalWrite(trig, LOW);
delayMicroseconds(2);
digitalWrite(trig, HIGH);
delayMicroseconds(10);
duration = pulseIn(echo, HIGH);
cm = microsecondsToCentimeters(duration);
if (cm > 10 and st==1){
alinha();
if (cm <= 10 and st==1){
Sonar2();
if (cm <= 10 and st==2){
pare();
if (cm > 10 and st==2){
frente();
if (cm > 10 and st==3){
frente();
if (cm <= 10 and st==3){
alinha2();
void controle(){
Serial.println(results.value, HEX);
armazenavalor = (results.value);
if (armazenavalor == 0xFF22DD) //Verifica se a tecla 1 foi acionada
pare();
if (armazenavalor == 0xFF02FD) //Verifica se a tecla 1 foi acionada
alinha();
if (armazenavalor == 0xFFC23D) //Verifica se a tecla 1 foi acionada
frente();
if (armazenavalor == 0xFF9867) //Verifica se a tecla 1 foi acionada
sensor();
irrecv.resume(); // Receive the next value
void frente() {
servo1.write(110);
servo2.write (70);
servo3.write (100);
delay(15);
void pare() {
servo2.write(94); //enviando um ângulo de 70 graus os servos param
servo3.write(94);
st = 1;
delay(200);
Sonar();
void Sonar() {
servo1.write(0);
delay(2000);
void Sonar2() {
servo1.write(180);
st=3;
delay(2000);
void alinha() { //alinhar o sonar com e motores
servo1.write(110);
for(int i=0;i<=10;i++) {
servo2.writeMicroseconds (1000);
servo3.writeMicroseconds (1000);
st = 2;
delay(30);
void alinha2() {
servo1.write(110);
servo2.writeMicroseconds (2000);
servo3.writeMicroseconds (2000);
st = 2;
delay(30);
The principle seems to be working properly, but I can not keep the command.
For example if I run a pause for a few seconds.
If I have a greater delay, the front() function does not work.
I tried the command while and do while and not execute another button.
Is there anything else I can do in this case?
juniormoura:
I'm sorry, I don't understand the problem. There is no function "front()". What, exactly, is not working the way you expected it to work and in what way is it different from what you expected. Since your variable names and comments are in a language that I can't understand and many of your functions have few or no comments I can't be of much help. You might want to see if there is a part of the forum for your native language and ask for further help there.
There are boards for: Deutsch, Español, Français, India, Italiano, Nederlands, Portugues, and Scandinavia. If none of those will work for you, you might consider changing your variable names and comments to English and adding comments that explain magic constants like 110, 70, and 94.
Sorry, I'm from Brazil.
I will change the name of the variables as you suggested and add comments.
I'll translate with google and what you do not understand you let me know.
This makes it easy for you to help me and understand what I'm thinking of doing in my project.
Hello, in my project I want when I turn on the robot, it moves through the ultrasonic sensor and when you press the power button on the remote control is triggered by movement control, allowing me to pause, advance or rewind.
And when you want to return the operation by ultrasonic sensor, press a button and returns to the sensor function.
# include <Servo.h>
# include <SPI.h>
# include <IRremote.h>
float num = 0;
Servo servo1;
Servo servo2;
Servo servo3;
int cm;
int st;
int trig = 6;
int echo = 7;
long microseconds;
/* Declaration of the IR =================== =================== */
RECV_PIN int = 11;
IRrecv irrecv (RECV_PIN);
infraredvalue long;
Serial.begin (9600);
irrecv.enableIRIn (); // Start the receiver
st = 2;
pinMode (trig, OUTPUT);
pinMode (echo, INPUT);
servo1.attach(8);
servo2.attach(9);
servo3.attach(10);
servo1.write(110);
servo2.write(70);
servo3.write(100);
delay (1000);
static boolean IRMode = true; // In IR Remote Start mode
sensor();
if (irrecv.decode (& results)) {
infraredvalue = results.value; // Receives the value read by the IR
Serial.println (infraredvalue, HEX);
if (infraredvalue == 0x1FE708F) {
IRMode = false;
// sensor ();
if (infraredvalue == 0x1FE48B7) {
IRMode = true;
// control ();
if (IRMode == true) {
control();
if (!IRMode) {
sensor();
irrecv.resume (); // Receive the next value
microsecondsToCentimeters long (long microseconds) {
return microseconds / 29/2;
void sensor() {
long duration, cm;
digitalWrite (trig, LOW);
delayMicroseconds (2);
digitalWrite (trig, HIGH);
delayMicroseconds (10);
duration = pulseIn (echo, HIGH);
cm = microsecondsToCentimeters (duration);
if (cm> 10 and st == 1) {// If the distance to the obstacle is greater than 10 cm align the sensor with the servomotors
align();
if (cm <= 10 and st == 1) {// If the distance to meet the condition for servomotor to 180 degrees
sonar2();
if (cm <= 10 and st == 2) {// If the distance to meet the condition servomotors stop
stop1();
if (cm > 10 and st == 2) {// If the distance to meet the condition sermotores advance
front();
if (cm >10 and st == 3) {// If the distance to meet the condition sermotores advance
front();
if (cm <= 10 and st == 3) {// If the distance to the obstacle is greater than 10 cm align the sensor with the servomotors
align();
void control () {
switch (infraredvalue) {
case 0x1FEA05F: // If the button is pressed 1FEA05F code servomotors stop
stop2 ();
// break;
case 0x1FE609F: // If the button is pressed 1FE609F code sensor with servo motors
align ();
// break;
case 0x1FE20DF: // If the button is pressed the code 1FE20DF sermotores advance
front ();
// break;
case 0x1FE8877: // If the button is pressed 1FE8877 code leaves the control function () and returns the sensor (function)
Sensor ();
// break;
/* BLOCK OF ALTERNATIVE TEST
void control () {
if (infraredvalue == 0x1FEA05F) // 1FEA05F Checks whether the key has been pressed
pare2 ();
if (infraredvalue == 0x1FE609F) // 1FE609F Checks whether the key has been pressed
align ();
if (infraredvalue == 0x1FE20DF) // 1FE20DF Checks whether the key has been pressed
front ();
// Back to the sensor
if (infraredvalue == 0x1FE8877) // 1FE8877 Checks whether the key has been pressed
sensor ();
// OS SERVOMOTORS BEEN MODIFIED TO ROTATE 360 DEGREES
void forward () {
servo1.write(110); // sending an angle of 110 degrees to align the sensor with the servomotors
servo2.write(70); // sending an angle of 70 degrees which is the point where the forward servo1
servo3.write(100); // sending an angle of 100 degrees which is the point where the forward servo2
delay (15);
void stop2() {
servo2.write(94); // sending an angle of 94 degrees which is the point where the stop servomotors
servo3.write(94); // sending an angle of 94 degrees which is the point where the stop servomotors
st = 1;
delay (200);
// sonar();
void stop1() {
st = 1;
delay (200);
Sonar ();
void sonar() {
servo1.write (0); // sending an angle of 0 degrees to see if there is any obstacle to the right
delay (2000);
void sonar2 () {
servo1.write (180); // sending an angle of 0 degrees to see if there is any obstacle to the left
st = 3;
delay (2000);
void align() {align // sonar with servomotors
servo1.write(110);
for (int i = 0; i <= 10; ++ i) {
st = 2;
delay (30);
void alinha2() {align // sonar with servomotors
servo1.write (110);
st = 2;
delay (30);
