Thanks to follow my problem!!
This is my code: (this is an exemple from the web in which i tried to insert my radio buttons )
//zoomkat 3-17-12
//simple button GET server code to control servo and arduino pin 4
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//Powering a servo from the arduino usually DOES NOT WORK.
//note that the below bug fix may be required
// Google Code Archive - Long-term storage for Google Code Project Hosting.
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservo; // create servo object to control a servo
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 0, 177 }; // ip in lan
byte gateway[] = { 192, 168, 0, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
void setup(){
pinMode(12, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
myservo.write(90); //set initial servo position if desired
myservo.attach(7); //the pin for the servo co
//enable serial data print
Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("");
client.println("");
client.println("Arduino GET test page");
client.println("");
client.println("");
client.println("
Simple Arduino button
// buttons
client.println("<a href="/?on"">ON");
client.println("<a href="/?off"">OFF
String stringOne = "ON1";
String stringTwo = "ON2";
char clientData[120];
client.println("test");
sprintf(clientData, "
<input type="button" value="%s" onmousedown="location.href ('/?%s');"/>", stringOne, stringTwo);
client.println(clientData);
client.println("test2");
client.println("
if(readString.indexOf("off357") >0)//checks for on
client.println("
Bouton all Off
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("on") >0)//checks for on
myservo.write(40);
digitalWrite(12, HIGH); // set pin 4 high
Serial.println("Led On");
if(readString.indexOf("off") >0)//checks for off
myservo.write(140);
digitalWrite(12, LOW); // set pin 4 low
Serial.println("Led Off");
//clearing string for next read
readString="";
