How to use WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
My Arduino IoT Cloud project is not connecting to my WiFi access point. It's an open network without a password.
In the Web Editor Monitor I get the following messages:
Connection to "linksys" failed
Retrying in "500" milliseconds
How do I use "WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);" without a password.
Thanks,
the parameters in the WiFiConnectionHandler are later used for calling   WiFi.begin(_ssid, _pass);
have you tried passing "" for the password ? the length (strlen(passphrase) is used) will be 0 and hopefully the WiFiDrv::wifiSetPassphrase() call will do the right thing
it's unfortunate they coded it this way as   WiFi.begin(_ssid);is the proper way to handle open wireless network.
--> you could edit the library to add one method with the limited signature and duplicate the other code (set _pass to NULL maybe or "") but just call WiFi.begin(_ssid); instead of WiFi.begin(_ssid, _pass);
(there might be other modifications if _pass is used elsewhere - I have not checked)
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, ""); worked
const char PASS[] = "";
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS); worked
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, NULL); did not work
Thank you for your help.
Good to know
Have fun!
