Continuing the discussion from Issues with I2C Communication on Waveshare RP2040-Zero:
Hi could you put the code where you used Wire1 to know how why it didn't work for me
have a look at RPi Pico RP2040 I2C scanner whic scans all the Wire and Wire1 interfaces for I2C devices
running on a RPi pico RP2040 with
results
I2C Scan
Wire0 SDA: 0 SCL: 1
No I2C devices found
Wire1 SDA: 2 SCL: 3
Wire0 SDA: 4 SCL: 5
I2C device found at address 0x68
I2C device found at address 0x76
Scan Complete
Wire1 SDA: 6 SCL: 7
Wire0 SDA: 8 SCL: 9
Wire1 SDA: 10 SCL: 11
Wire0 SDA: 12 SCL: 13
Wire1 SDA: 14 SCL: 15
Scan Complete
Wire0 SDA: 16 SCL: 17
Wire1 SDA: 18 SCL: 19
Wire0 SDA: 20 SCL: 21
Wire1 SDA: 26 SCL: 27
All Scans Successful!
The problem I have is that I want to use gpio 26 and 27 of the i2c to be able to connect in gpio4 and 5 another SPI device but nothing has worked I can't enable pins 26 and 27 and when connecting the i2c device it uses pins 4 and 5 and pin 4(MISO) is used by the SPI device and creates conflict.
I'm connecting a RTC clock module by i2c and a microsd card reader module by SPI but the pins that by default are enabled the gpio4 is shared by i2c and SPI and creates conflict what can I do?
which version of the RP2040 are you using?
not sure what you are attempting to connect to the RP2040
what else do you want to connect?
what pins are you attempting to use for what devices?
Versión waveshare rp2040 Zero
pins 26 and 27 are I2C1 SDA and SCL and are therefore associated with Wire1
here is an example of a BMP280 connected to pins 26 and 27 of a RPi Pico RP2040
// Interfacing RPi pico RP2040 with BMP280 temperature and pressure sensor.
#include <Wire.h> // include Wire library, required for I2C devices
#include <Adafruit_Sensor.h> // include Adafruit sensor library
#include <Adafruit_BMP280.h> // include adafruit library for BMP280 sensor
// define device I2C address: 0x76 or 0x77 (0x77 is library default address)
#define BMP280_I2C_ADDRESS 0x76
// define I2C1 RP2040 pins for BMP280
#define SDA 26
#define SCL 27
Adafruit_BMP280 bmp280(&Wire1);
delay(3000);
Serial.println(F("RPi pico RP2040 + BMP280"));
Wire1.setSDA(SDA); // setup SDA and SCL pins
Wire1.setSCL(SCL);
Wire1.begin();
if (!bmp280.begin(BMP280_I2C_ADDRESS)) {
Serial.println("Could not find a valid BMP280 sensor, check wiring!");
while (1)
Serial.println("Found BMP280 sensor!");
// get temperature, pressure and altitude from library
float temperature = bmp280.readTemperature(); // get temperature
float pressure = bmp280.readPressure(); // get pressure
float altitude_ = bmp280.readAltitude(1013.25); // get altitude (this should be adjusted to your local forecast)
// print data on the serial monitor software
// 1: print temperature
Serial.print("Temperature = ");
Serial.print(temperature);
Serial.println(" °C");
// 2: print pressure
Serial.print("Pressure = ");
Serial.print(pressure / 100);
Serial.println(" hPa");
// 3: print altitude
Serial.print("Approx Altitude = ");
Serial.print(altitude_);
Serial.println(" m");
Serial.println(); // start a new line
delay(2000); // wait 2 seconds
a run gives
Temperature = 23.30 °C
Pressure = 997.76 hPa
Approx Altitude = 129.76 m
Temperature = 23.61 °C
Pressure = 997.82 hPa
Approx Altitude = 129.25 m
Temperature = 23.62 °C
Pressure = 997.83 hPa
Approx Altitude = 129.21 m
ok I'll try it thanks
Add the elements of your code and connect the RTC to pins 26 and 27 and I get this:
C:\Users\aaa\Documents\relojRTCparaWaveshareRP2040Zero\relojRTCparaWaveshareRP2040Zero.ino: In function 'void loop()':
C:\Users\aaa\Documents\relojRTCparaWaveshareRP2040Zero\relojRTCparaWaveshareRP2040Zero.ino:42:23: error: request for member 'now' in 'rtc', which is of non-class type 'RTC_DS3231()'
42 | DateTime fecha = rtc.now();
exit status 1
Compilation error: request for member 'begin' in 'rtc', which is of non-class type 'RTC_DS3231()'
think you need to post the whole code
This code works ok, SDA on gpio04,SCL on gpio05 , how to change SDA to gpio26 and SCL to gpio27?
#include "RTClib.h"
int LED_BUILTIN =16;
RTC_DS3231 rtc;
String daysOfTheWeek[7] = { "Domingo", "Lunes", "Martes", "Miercoles", "Jueves", "Viernes", "Sabado" };
String monthsNames[12] = { "Enero", "Febrero", "Marzo", "Abril", "Mayo", "Junio", "Julio","Agosto","Septiembre","Octubre","Noviembre","Diciembre" };
void printDate(DateTime date)
Serial.print(date.year(), DEC);
Serial.print('/');
Serial.print(monthsNames[date.month()-1]);
Serial.print('/');
Serial.print(date.day(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[date.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(date.hour(), DEC);
Serial.print(':');
Serial.print(date.minute(), DEC);
Serial.print(':');
Serial.println(date.second(), DEC);
Serial.println("___________________________________________________");
void setup(){
if (!rtc.begin()) {
Serial.println(F("No se encuentra RTC"));
//while (1);
if (rtc.lostPower()) {
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
void loop(){
DateTime hoy = rtc.now();
printDate(hoy);
it is always a good idea to test each device in a separate program in case devices, libraries, etc corrupt each other or cause other problems
when all are working start building the complete system
e.g. testing DS32341 on a RPi pico
// RPi pico RP2040 Date and time functions using a DS3231 RTC
// connected via I2C1 and Wire1 using pins 26 SDA and 27 SCL
#include <Wire.h>
#include "RTClib.h"
// define I2C1 RP2040 pins for DS3231
#define SDA 26
#define SCL 27
RTC_DS3231 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
void setup () {
#ifndef ESP8266
while (!Serial); // for Leonardo/Micro/Zero
#endif
delay(3000); // wait for console opening
Serial.println(F("RPi pico RP2040 + DS3231 RTC"));
Wire1.setSCL(SCL);
Wire1.begin();
if (! rtc.begin(&Wire1)) {
Serial.println("Couldn't find RTC");
while (1);
Serial.println("RTC lost power, lets set the time!");
// following line sets the RTC to the date & time this sketch was compiled
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
Serial.println("RTC initialised!");
void loop () {
DateTime now = rtc.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
Serial.print(") ");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.print(" since midnight 1/1/1970 = ");
Serial.print(now.unixtime());
Serial.print("s = ");
Serial.print(now.unixtime() / 86400L);
Serial.println("d");
// calculate a date which is 7 days and 30 seconds into the future
DateTime future (now + TimeSpan(7,12,30,6));
Serial.print(" now + 7d + 30s: ");
Serial.print(future.year(), DEC);
Serial.print('/');
Serial.print(future.month(), DEC);
Serial.print('/');
Serial.print(future.day(), DEC);
Serial.print(' ');
Serial.print(future.hour(), DEC);
Serial.print(':');
Serial.print(future.minute(), DEC);
Serial.print(':');
Serial.print(future.second(), DEC);
delay(3000);
a run gave
RTC initialised!
2024/5/2 (Thursday) 18:11:39
since midnight 1/1/1970 = 1714673499s = 19845d
now + 7d + 30s: 2024/5/10 6:41:45
2024/5/2 (Thursday) 18:11:42
since midnight 1/1/1970 = 1714673502s = 19845d
now + 7d + 30s: 2024/5/10 6:41:48
2024/5/2 (Thursday) 18:11:45
since midnight 1/1/1970 = 1714673505s = 19845d
now + 7d + 30s: 2024/5/10 6:41:51
2024/5/2 (Thursday) 18:11:48
since midnight 1/1/1970 = 1714673508s = 19845d
now + 7d + 30s: 2024/5/10 6:41:54
2024/5/2 (Thursday) 18:11:51
since midnight 1/1/1970 = 1714673511s = 19845d
now + 7d + 30s: 2024/5/10 6:41:57
2024/5/2 (Thursday) 18:11:54
since midnight 1/1/1970 = 1714673514s = 19845d
now + 7d + 30s: 2024/5/10 6:42:0
2024/5/2 (Thursday) 18:19:51
since midnight 1/1/1970 = 1714673991s = 19845d
now + 7d + 30s: 2024/5/10 6:49:57
2024/5/2 (Thursday) 18:19:54
since midnight 1/1/1970 = 1714673994s = 19845d
now + 7d + 30s: 2024/5/10 6:50:0
2024/5/2 (Thursday) 18:19:57
since midnight 1/1/1970 = 1714673997s = 19845d
now + 7d + 30s: 2024/5/10 6:50:3
The code worked perfectly, thank you very much, have a nice day.
if the code of post 11 was the answer mark it as the solution to help other users with the same problem
Hello to the above code I added an ldr resistor to read its values on the pin gpio29 and the reads are altered by the SDA and SCL pins because when disconnecting the RTC module the readings are normal, how can I fix this?
Hello, the solution was to change the SDA pins to gpio 6 and SCL to gpio 7 and so I got the correct readings of the LDR resistor thanks
