How to use XBEE bluetooth module hc-06? plz help me:(
i will use XBee bluetooth module that aply hc-06 communication.
that module have a xbee shield and i want connect with arduino hc-06 module.
i know that communication way between hc-06 to hc-06.
that source code is
#include <SoftwareSerial.h>
SoftwareSerial bluetooth(2,3);
  bluetooth.begin(9600);
  if(bluetooth.available()){
    Serial.write(bluetooth.read());
  if(Serial.available()){
    bluetooth.write(Serial.read());
like this. i can set up arduino hc-06 module to master mode using this code.
but, since xbee bluetooth module have a xbee shield, so i can't set up
this line that TX pin and RX pin.
it is hard to connect with two module.
plz, can get some information or answer about this problem that hc-06 module connect with xbee blue tooth module that have xbee shield....?
plz help me:(
No you can't, HC-06 is slave only.
Same applies. One Bluetooth must be HC-05.
i understand your mean. so, in conclusion, if i want to connect two module, i have to use hc-05 module.
and then communication way is same as hc-06 to hc-06. is this correct?
if i have a hc-05 module. how do i connect xbee bluetooth module to hc-05?
i'm curious that hc-05 is easy to declare TX,RX pin like
but xbee bluetooth module (i know that this module support HC-03,04,05,06) that have xbee shield is not declare like hc-05 module.
How to set the transmit receive pin for xbee module with code??:frowning:
yes but you only need one, the other can be HC-06
No. there is no such thing as HC-06 to HC-06 comms
check here link
Note that all the real work is done by HC-05. The HC-06 is just a slave.
An HC-05 on an XBee board should work just like any other HC-05, and use the same software commands.
All you need do is ensure the proper pins are connected to Arduino. This presupposes the proper pins are identified on the XBee board. It also presupposes you have kosher power to the XBee
If xbee bluetooth module is used as hc-06 and other bluetooth module is used as hc-05, it means that communication is possible, right?
If I simply use hc-06 or hc-05 Bluetooth, I can set it as a digital input pin because the pin is out, but if I use the xbee shield board, it is difficult to set the tx rx pin because the tx and rx pins of the xbee are not exposed outside.....
so you mean that ,
Then, in order to give a command to set the Tx and Rx pins on the xbee shield board (hc-06), I have to refer to the data sheet, check the RX, TX pins, and enter the command ?
like
Yes. It doesn't actually matter which is which, so long as one is a master (HC-05).
Incoherent, and no comment. I don't know anything about XBee
so you mean that ,
like
Yes. I understand XBee is a stand-alone device, and I guess you don't have the flexibility of Arduino.
Blockquote
