How to use Z axis of hmc5883l?The data for tilt compensation?
I find out some code from github.But it seems just use x and y axis data.This code work fine only the hmc5883l module horizontal placement.I think it's not use Z axis reason right?
  // Calculate heading
  float heading = atan2(norm.YAxis, norm.XAxis);
  // Set declination angle on your location and fix heading
  // You can find your declination on: http://magnetic-declination.com/
  // (+) Positive or (-) for negative
  // For Bytom / Poland declination angle is 4'26E (positive)
  // Formula: (deg + (min / 60.0)) / (180 / M_PI);
  float declinationAngle = (4.0 + (26.0 / 60.0)) / (180 / M_PI);
  heading += declinationAngle;
  // Correct for heading < 0deg and heading > 360deg
  if (heading < 0)
    heading += 2 * PI;
  if (heading > 2 * PI)
    heading -= 2 * PI;
  // Convert to degrees
  float headingDegrees = heading * 180/M_PI;
For tilt compensation you need to use all three magnetometer axes and to measure the tilt, a 3D accelerometer.
Pololu has good tilt compensation code, which can be used with their better performing LSM303D magnetometer/accelerometer module, or adapted to other sensors.
Now I have a question:
Where it is used the z axis.To my understanding,it is used for tilt compensation.
All three axes of the magnetometer are needed to measure the strength and direction of the Earth's (or some other) magnetic field.
Yes, the magnetometer Z axis is used in tilt compensation, but the magnetometer alone does not provide enough information to make a tilt compensated compass. You can read about the theory here: https://cache.freescale.com/files/sensors/doc/app_note/AN4248.pdf.
Thank all of you
