how to wait for input on touch panel, MIO283QT
hi,
I bought a display MIO283QT with ARM controller on a SD-card shield from Watterott.
The example sketches for display, Dispal_SPI.ino, and touch panel, Touch_SPI.ino are working.
Both sketches are using base commands like CMD_LCD_CLEAR, CMD_LCD_DRAWLINE and so on.
Now I want to combine both. I added code to the function “wait_for_input()” to wait for input from the touch panel TP (see code later).
I tried it with CMD_TP_WAITPRESS but the code does not wait for touching the TP.
I also tried it like in the example code with waiting for the pressing level z>0. Now the code is waiting but touching/pressing the TP does not finish waiting, i.e. the code is waiting for ever.
Original code:
void wait_for_input(void)
  Serial.println("Wait for input!");
  while(Serial.available() == 0);
  while(Serial.available() != 0){ Serial.read(); };
My version should wait for input on serial monitor or TP:
void wait_for_input(byte ser_tp)
  uint16_t x, y, z=0;
  if (ser_tp ==2) {
    Serial.println("Wait for input on TP");
    digitalWrite(cs_pin, LOW);
//    SPI.transfer(CMD_TP_CALIBRATE);
//    delay(10);
//    SPI.transfer(0xFF); //read response
//    delay(10);
//    z=0;
    while (z == 0) {  // here the code should wait for pressing the TP
      SPI.transfer(CMD_TP_POS);
      delay(1);
      x  = SPI.transfer(0xFF)<<8;
      x |= SPI.transfer(0xFF)<<0;
      y  = SPI.transfer(0xFF)<<8;
      y |= SPI.transfer(0xFF)<<0;
      z  = SPI.transfer(0xFF)<<8;
      z |= SPI.transfer(0xFF)<<0;
      delay(2);
    digitalWrite(cs_pin, HIGH);
    Serial.print("TP response: ");
    Serial.print(x); Serial.print(" ");
    Serial.println(y);
  else {
    Serial.println("Wait for input on serial monitor");
The call wait_for_input(2) is used after all initializations of the display.
Ha somebody experience using this type of display?
Do you have activated the touch panel?
//enable touchpanel
SPI.transfer(CMD_CTRL);
SPI.transfer(CMD_CTRL_FEATURES);
SPI.transfer(FEATURE_TP);
uint16_t x=0, y=0, z=0;
while (z == 0)
  //read data
  delay(1);
  delay(20);
You can also use our Arduino Library: DisplayI2C or DisplaySPI + GraphicsLib.
Here is an example for the lib:
Regards
Andreas
