How to wait for IR remote signal and then execute a code if no signal received?
Here's what I want to do:
  1. Wait for a particular IR remote signal (e.g.- button 5 on remote)
  2. If no signal is detected within 60s, turn on LED for 30s, then turn everything off (if that's possible in arduino)
This is the code I have now. It turns on pin 9 when I press "5" on my remote.
 Some Sample code of how to use your IR remote
 * Lets get started:
 The IR sensor's pins are attached to Arduino as so:
 Pin 1 to Vout (pin 11 on Arduino)
 Pin 2 to GND
 Pin 3 to Vcc (+5v from Arduino)
#include <IRremote.h>
int IRpin = 11;  // pin for the IR sensor
int LED = 9;    // LED pin
IRrecv irrecv(IRpin);
decode_results results;
boolean LEDon = false; // initializing LEDon as true
  irrecv.enableIRIn(); // Start the receiver
  pinMode(LED, OUTPUT);
  if (irrecv.decode(&results))
      irrecv.resume();   // Receive the next value
   if (results.value == 0xFF38C7)  // change zero to your IR remote button number
       if (LEDon == false)   // is LEDon equal to true?
           LEDon = true;
           digitalWrite(LED, HIGH);
           delay(100);      // keeps the transistion smooth
            LEDon = false;
            digitalWrite(LED, LOW);
            delay(100);
My goal is to start the code in case IR remote is out of range. Can't think of an algorithm for that without thinking about running something in parallel. So, it's like this: we got IR signal? Great! Let remote control take over. No IR signal within 60s? Time to run that contingency code.
Wait starting when?
  1. If no signal is detected within 60s
Within 60 seconds of what? The big bang? Oops, too late for that.
At the start of the timing interval you need to save the value of millis() - for example
startMillis = millis();
Then you need to check regularly if the interval has elapsed
if (millis() - startMillis >= interval) {
   // timeout period has expired
If you want the receipt of a particular IR code to restart the timing interval then you need code like
            // your other stuff
...R
Robin2:
           // your other stuff
...R
srk999:
Yes.
...R
How will you distinguish between "out of range" and "no button being pressed"?
If I get your car running in a circle, slowly, I don't want you stopping it because I've waited more than 60 seconds before getting bored.
