Hello uxomm!
The code i used is from the DS3232 on Github, here’s the code:
* Display the date and time from a DS3231 or DS3232 RTC every second. *
* Display the temperature once per minute. (The DS3231 does a *
* temperature conversion once every 64 seconds. This is also the *
* default for the DS3232.) *
* Set the date and time by entering the following on the Arduino *
* serial monitor: *
* year,month,day,hour,minute,second, *
* Where *
* year can be two or four digits, *
* month is 1-12, *
* day is 1-31, *
* hour is 0-23, and *
* minute and second are 0-59. *
* Entering the final comma delimiter (after "second") will avoid a *
* one-second timeout and will allow the RTC to be set more accurately. *
* No validity checking is done, invalid values or incomplete syntax *
* in the input will result in an incorrect RTC setting. *
* Jack Christensen 08Aug2013 *
* Tested with Arduino 1.0.5, Arduino Uno, DS3231/Chronodot, DS3232. *
* This work is licensed under the Creative Commons Attribution- *
* ShareAlike 3.0 Unported License. To view a copy of this license, *
* visit http://creativecommons.org/licenses/by-sa/3.0/ or send a *
* letter to Creative Commons, 171 Second Street, Suite 300, *
* San Francisco, California, 94105, USA. *
#include <DS3232RTC.h> //http://github.com/JChristensen/DS3232RTC
#include <Streaming.h> //http://arduiniana.org/libraries/streaming/
#include <Time.h> //http://playground.arduino.cc/Code/Time
#include <Wire.h> //http://arduino.cc/en/Reference/Wire
void setup(void)
//setSyncProvider() causes the Time library to synchronize with the
//external RTC by calling RTC.get() every five minutes by default.
setSyncProvider(RTC.get);
Serial << F("RTC Sync");
if (timeStatus() != timeSet) Serial << F(" FAIL!");
Serial << endl;
void loop(void)
static time_t tLast;
time_t t;
tmElements_t tm;
//check for input to set the RTC, minimum length is 12, i.e. yy,m,d,h,m,s
if (Serial.available() >= 12) {
//note that the tmElements_t Year member is an offset from 1970,
//but the RTC wants the last two digits of the calendar year.
//use the convenience macros from Time.h to do the conversions.
int y = Serial.parseInt();
if (y >= 100 && y < 1000)
Serial << F("Error: Year must be two digits or four digits!") << endl;
else {
if (y >= 1000)
tm.Year = CalendarYrToTm(y);
else //(y < 100)
tm.Year = y2kYearToTm(y);
tm.Month = Serial.parseInt();
tm.Day = Serial.parseInt();
tm.Hour = Serial.parseInt();
tm.Minute = Serial.parseInt();
tm.Second = Serial.parseInt();
t = makeTime(tm);
RTC.set(t); //use the time_t value to ensure correct weekday is set
setTime(t);
Serial << F("RTC set to: ");
printDateTime(t);
Serial << endl;
//dump any extraneous input
while (Serial.available() > 0) Serial.read();
t = now();
if (t != tLast) {
tLast = t;
printDateTime(t);
if (second(t) == 0) {
float c = RTC.temperature() / 4.;
float f = c * 9. / 5. + 32.;
Serial << F(" ") << c << F(" C ") << f << F(" F");
Serial << endl;
//print date and time to Serial
void printDateTime(time_t t)
printDate(t);
Serial << ' ';
printTime(t);
//print time to Serial
void printTime(time_t t)
printI00(hour(t), ':');
printI00(minute(t), ':');
printI00(second(t), ' ');
//print date to Serial
void printDate(time_t t)
printI00(day(t), 0);
Serial << monthShortStr(month(t)) << _DEC(year(t));
//Print an integer in "00" format (with leading zero),
//followed by a delimiter character to Serial.
//Input value assumed to be between 0 and 99.
void printI00(int val, char delim)
if (val < 10) Serial << '0';
Serial << _DEC(val);
if (delim > 0) Serial << delim;
return;
The code below that can set and read the time, so i think the circuit is correct.
My goal is to make the DS3232 output the square wave.
#include "Wire.h"
#define DS3231_I2C_ADDRESS 0x68
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return( (val/16*10) + (val%16) );
Wire.begin();
// set the initial time here:
// DS3231 seconds, minutes, hours, day, date, month, year
//setDS3231time(20,8,15,1,8,1,17);
void setDS3231time(byte second, byte minute, byte hour, byte dayOfWeek, byte
dayOfMonth, byte month, byte year)
// sets time and date data to DS3231
Wire.beginTransmission(DS3231_I2C_ADDRESS);
Wire.write(0); // set next input to start at the seconds register
Wire.write(decToBcd(second)); // set seconds
Wire.write(decToBcd(minute)); // set minutes
Wire.write(decToBcd(hour)); // set hours
Wire.write(decToBcd(dayOfWeek)); // set day of week (1=Sunday, 7=Saturday)
Wire.write(decToBcd(dayOfMonth)); // set date (1 to 31)
Wire.write(decToBcd(month)); // set month
Wire.write(decToBcd(year)); // set year (0 to 99)
Wire.endTransmission();
void readDS3231time(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
Wire.write(0); // set DS3231 register pointer to 00h
Wire.requestFrom(DS3231_I2C_ADDRESS, 7);
// request seven bytes of data from DS3231 starting from register 00h
*second = bcdToDec(Wire.read() & 0x7f);
*minute = bcdToDec(Wire.read());
*hour = bcdToDec(Wire.read() & 0x3f);
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
void displayTime()
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
// retrieve data from DS3231
readDS3231time(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month,
&year);
// send it to the serial monitor
Serial.print(hour, DEC);
// convert the byte variable to a decimal number when displayed
Serial.print(":");
if (minute<10)
Serial.print("0");
Serial.print(minute, DEC);
Serial.print(":");
if (second<10)
Serial.print("0");
Serial.print(second, DEC);
Serial.print(" ");
Serial.print(dayOfMonth, DEC);
Serial.print("/");
Serial.print(month, DEC);
Serial.print("/");
Serial.print(year, DEC);
Serial.print(" Day of week: ");
switch(dayOfWeek){
case 1:
Serial.println("Sunday");
case 2:
Serial.println("Monday");
case 3:
Serial.println("Tuesday");
case 4:
Serial.println("Wednesday");
case 5:
Serial.println("Thursday");
case 6:
Serial.println("Friday");
case 7:
Serial.println("Saturday");
displayTime(); // display the real-time clock data on the Serial Monitor,
delay(1000); // every second
