How to wire a V5 Shield properly
Hello,
I will put my custom components in a V5 shield.
Is simple
Two screw terminals for 7 external connections
Two resistors
Two electrolytic capacitors
One 7812 regulator
The question is:
I need to use pins 9, 10 and 11
I see two ways of wiring them
A. Solder small wires as indicated in the pic to connect those signals to my custom rails
B. Use a 90 degree bent pluged in the upper part and the solder the three wires to the shield pcb
Which is the best way ?
For GND and +5 this is not necesary because of the rails provided
Thanks a lot
Horacio
That is called a "Prototype Shield".
You can make the connections you showed, or bring them up a little farther to the "Group of 3 holes connected together".
You get to decide most of the wiring layout on a proto board.
Thank you Terry,
I will follow your way and perhaps mount everything on a small white proto board that fits the shield size.
Have a nice day !
Horacio
Sorry, I must have been confusing.
The Shield you have is a "Proto Shield" which is a type of protoboard with Arduino
pins. You don't necessarily need an added proto board..
