HOW TO WIRE ARDUINO TB6560 CNC Driver and 3xNEMA 17 STEPPERs
I use an ARDUINO Mega Card,
and the contoller :
3 Axis TB6560 CNC Stepper Motor Driver Controller Board
And 3 NEMA 17 Stepper motors
Please help me WIRING
usually this controller card have parallel or usb port,
btw i think you have the paraller port one so the problem may be is to use it on a pc without parallel port,
so you need a cnc parallel board adapter, foundable on ebay.
with arduino i don't know how to simulate the parallel port, but by logic it should be possible
If this is the Chinese stepper driver board from Ebay it will drive those motors directly. As Italy77 said it is designed for driving from a PC's printer port however all the signals to drive it go straight to a 74HC14 Schmitt trigger IC so there shouldn't be any problem to drive it from an Arduino.
There is a schematic here that shows you the connections.
Russell.
