Can someone show me how to wire ESP8266 nodeMCU to powerbank/battery T_T
does it need some module or other components?
"we don't want it connected to a laptop"
It is pretty straight forward, but, you need to make sure that the ESP8266 can handle the voltage from the powerbank, otherwise, you might need to add some resistors or use some kind of voltage regulator to lower the voltage.
You just need to connect GND -> GND and V -> V.
What kind of powerbank do you have? What connector does it have?
Br Max
It's called USB cable, no need for other components.
I've already tried this it's not working
does it need to have powersuppply module?
You may have a powerbank of the sort that needs a minimum load, current draw, to keep it active (alive).
Never had a power bank that doesn't power nodeMcu. Obviously it has to be charged to work...
when both the Arduino and Esp are connected to a laptop it works but when we put it on a powerbank it does not
When both the Arduino and Esp are connected to a laptop it works but when we put it on a powerbank/battery it does not.
Please help us ![]()
what you mean both?
Much more detail please
Which Arduino ?
Which ESP8266 ?
How are they connected ?
What sketch or sketches are running ?
What are they supposed to do ?
Your two or more topics on the same or similar subject have been merged.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
my apologies ![]()
If you do not understand Post No.6 - say so.
A NodeMCU running the WiFi pulls 100mA or so. There are certain powerbanks that will not stay ON (they will auto-off in 15sec or so) if the current drawn from them is less than 200-250mA.
Also, from where that arduino jumped in to this game?
Are you powering arduino from computer and esp8266 from powerbank and these two are connected somehow??
The similarities. . .
Are you and @swish16 working together on this project ?
