How to wire SD Card Module with Arduino MKR GSM 1400?
I have bought an SD Module with the following Pin-Names: VCC,GND,MISO,MOSI,CS,SCK. I have found many tutorials on how to use it with the Arduino Uno. But haven't found any on how to wire it with mine. Most of these Pin Names are written on the Board itself, but the CS-port isn't marked. (VCC and GND are obvious). So do you know how I can wire it? Especially the CS pin.
jgartner: I have bought an SD Module with the following Pin-Names: VCC,GND,MISO,MOSI,CS,SCK. I have found many tutorials on how to use it with the Arduino Uno. But haven't found any on how to wire it with mine. Most of these Pin Names are written on the Board itself, but the CS-port isn't marked. (VCC and GND are obvious). So do you know how I can wire it? Especially the CS pin.
Which pin does the CS use on the Arduino?
Which library are you planning on using?
Hi, did you solve this? Be careful. Once I connected my MKR GSM 1400 to SPI MicroSD module and I broke my MKR board.
Maybe using of step up/down (5V/3.3V) convertor is needed.
Could anyone help us with this problem?
