How to work the external power supply management ?
I would like to know, how work the operational amplifier connected (LM358D) to the P-Channel MOSFET transistor (FDN304V)
This part of Arduino board is used to connect the regulator (5V) to USB VCC, when external power supply is connected on the Arduino board.
—> http://arduino.cc/en/uploads/Main/arduino-uno-schematic.pdf
The LM358D is a voltage comparator :
CMP : on pin 3 of LM358D (+ input)
+3V3 : on pin 2 of LM358D (- input)
GATE_CMD : pin 1 of LM358D (output)
With CMP = (VIN / 2)
CMP > +3V3 : GATE_CMD = +5V
CMP < +3V3 : GATE_CMD = 0V
—> http://fr.wikiversity.org/wiki/Amplificateur_opérationnel/Comparateur
The P-Channel MOSFET transistor (FDN304V) needs a negative Gate Threshold Voltage.
—> http://www.adrirobot.it/datasheet/transistor/pdf/FDN304P.pdf
But the LM538D output connected on the Gate of this transistor (GATE_CMD) is between 0V to +5V but a never negative value !
I don’t know how it is work…
Thanks
Nassa.
It is relative to the source of the FET.
Hi Grumpy Mike,
Ok, I understood ! When the GATE_CMD is on 0V then the Ugs is -5V. the FET threshold is reach.
Thanks very much.
I understood the step where there is not external supply, and therefore VG = 0V and VD = 5V from USB. However, at the first instant, also VS should be 0V due to the inexistence of external supply and the MOSFET will not work, with VGS = 0V. How it works then?
Regards, Antonio
