How to work with subroutines?
hello, i need help on using a goto statement. i a doing traffic light signal.my program is supposed to go to a line if a switch button is on.here is my code;
int trafficLights1[] = {2,3,4,5};	// red, yellow, green, pedestrians led pins
int trafficLights2[] = {6,7,8,9};	// red, yellow, green, pedestrians led pins
int situations = 4;
int duration[] = {8000,3000,10000,3000}; // duration of each situation
long previousCars = 0;
long previousPeds = 0;
long interval = 300;	//blink interval for pedestrians
int ledState = LOW;
int state;
int i = 0;
  for(int i = 0; i < 4; i++) {
	  pinMode(trafficLights1[i], OUTPUT);
	  pinMode(trafficLights2[i], OUTPUT);
	if(currentMillis - previousCars < duration[i]) {
		situation(i);
		previousCars = currentMillis;
		if(i >= situations) {
			i = 0;
			i++;
void activateTrafficLight1(String lights, int pedestrians)
	for(int x = 0; x < 3; x++)
		if(lights[x] == '0') state = LOW;
		if(lights[x] == '1') state = HIGH;
		digitalWrite(trafficLights1[x], state);
	if(pedestrians == 1) {
		blinkPed(trafficLights1[3]);
		digitalWrite(trafficLights1[3], LOW);
void activateTrafficLight2(String lights, int pedestrians)
		digitalWrite(trafficLights2[x], state);
		blinkPed(trafficLights2[3]);
		digitalWrite(trafficLights2[3], LOW);
void situation(int i)
	switch(i){
		case 0:
			activateTrafficLight1("100",1); // 100 means red ON, yellow OFF, green OFF
			activateTrafficLight2("001",0); // the second parameter is for pedestrians
			break;							// 1 is ON and 0 is OFF
		case 1:
			activateTrafficLight1("110",0); // 110: red ON, yellow ON, green OFF
			activateTrafficLight2("010",0);
		case 2:
			activateTrafficLight1("001",0);
			activateTrafficLight2("100",1);
		case 3:
			activateTrafficLight1("010",0);
			activateTrafficLight2("110",0);
void blinkPed(int ped) {
	if(currentMillis - previousPeds > interval) {
		previousPeds = currentMillis;
		if (ledState == LOW)
		ledState = HIGH;
		ledState = LOW;
		digitalWrite(ped, ledState);
I think you mean that you need help in getting rid of gotos in your code. Using them leads to code that is hard to maintain because it is hard to follow the logic. They are never necessary. Instead call a function to perform actions when you detect that a switch state has changed.
Start by editing your post, selecting the code and clicking the code icon </> at the left of the icons above the editor window. That will prevent your code being interpretted as HTML and being mangled as it is now.
You've come to the wrong place. Try over at http://moronCoders.com.
You may find some useful stuff in Planning and Implementing a Program. It uses functions for most things.
...R
@purinko, you not only hijacked an ancient thread, but you also never read the forum rules and guidelines about how to post.
