How to write a funtion that takes strings in flash for argument.
How can I fix the function do_something in the above code so that it accepts both regular and flash strings?
Full sketch:
	do_something("blah blah") ; /// Ok
	do_something(F("blah")) ; /// Does not compile
void do_something(const char text[])
	Serial.println(text) ;
You have the source of the F() macro, and the functions which use it - why not see how they work?
I do respect your time. I never post a question until I have done everything to find the answer by myself. and, yes, I have learned a lot about the F macro and the like. this blog post was one of the most helpful.
Sayiing that, if you have an answer to my question, I would be very glad to go a step further :wink:
The keyword is __FlashStringHelper. It is an undefined type used to mark strings stored in Flash using the F-macro. The type and macro are defined here...
https://github.com/arduino/Arduino/blob/master/hardware/arduino/avr/cores/arduino/WString.h#L37
This is how to prototype a function that uses an F-macro parameter...
https://github.com/arduino/Arduino/blob/master/hardware/arduino/avr/cores/arduino/Print.h#L58
And this is how to implement the function...
https://github.com/arduino/Arduino/blob/master/hardware/arduino/avr/cores/arduino/Print.cpp#L42
The short answer is that you will have to overload that function so that there are two versions, one that takes a regular char* string and one that takes a __FlashStringHelper*.
Many thanks to Coding Badly and Delta_G.
Here is the solution I managed to write:
#include <PString.h> /// http://arduiniana.org/libraries/pstring/
	do_something(F("blah blah")) ;
	do_something("blah") ;
	Serial.println("Done") ;
void loop() {}
void do_something(char *t)
	String s(t) ;
	s+= " !" ;
	Serial.println(s) ;
void do_something(const __FlashStringHelper *t)
	char buf[30] ;
	PString s(buf, 30) ;
	s.print(t) ;
	do_something(buf) ;
Lessons learned:
  • __FlashStringHelper* cannot be cast to char*.
  • I had to overload my function to handle this type (as Delta_G said).
  • Data in Flash can only be read one byte at a time.
  • PString can do that for me.
No different to RAM
