How to write and read 4 Digit Sensor vaule in EEPROM
Hello Friends,
I am new learner and not good in coding too.But aim is to learn .Basically my project is to measure temperature uptp 1200 DegC.
for that purpose I googled many examples, tried to modify according to my need using Max6675.
Code is working perfectly & displaying Temp on serial Monitor,even simulator is used to read Temp upto 1140 Deg C with slightly difference
+-6 DegC, for the moment accuracy is not so important.
The issue is which I have been facing from last 2 Weeks,eeprom store only value upto 250 DegC perfectly but beyond it doesnt store correctly.
In my case I have to store value upto 1200 DegC.
Could you please help me with code modification to store 4 Digit Value into eeprom?
Your help would be greatly appriciated.
Thanks,
Rezox
Look at the EEPROM library's put and get functions
Here is my code:
#include <EEPROM.h>
#include "max6675.h"
#define SAMPLE_TIME 2000  //The time between each EEPROM write function call in ms
int printPin = 2;     //the print button pin
int erasePin = 4;    //the erase button pin
int thermoDO = 5;
int thermoCS = 4;
int thermoCLK = 6;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
int address = 0;      //EEPROM address counter
int counter = 0;
unsigned long timer;
unsigned long int milli_time;
void printTemp();
void clearEEPROM();
void writeTemp();
void setup(){
  Serial.begin(115200);     //start the serial connection as always
  pinMode(printPin, INPUT_PULLUP);
  pinMode(erasePin, INPUT_PULLUP);
  timer = millis();         //millis() returns the time since program start in ms
void loop(){
  if(millis()-timer > SAMPLE_TIME)  //check if it's time to do a temp sensor sample
    writeTemp();
    timer = millis();
  if(!digitalRead(printPin))  //check if print button is pressed
    printTemp();
  if(!digitalRead(erasePin)) //check if erase button is pressed
    clearEEPROM();
  delay(1);
void printTemp()
  for (int i = 0 ; i < EEPROM.length() ; i++) {
    byte value = EEPROM.read(i);                //read EEPROM data at address i
    if(value != 0)                              //skip "empty" addresses
      sumTemp = sumTemp + thermocouple.readCelsius();
      Serial.println(sumTemp);
void clearEEPROM()
    if(EEPROM.read(i) != 0)                     //skip already "empty" addresses
      EEPROM.write(i, 0);                       //write 0 to address i
  Serial.println("EEPROM erased");
  address = 0;                                  //reset address counter
void writeTemp()
       milli_time = millis();
    sumTemp = sumTemp + thermocouple.readCelsius();            // basic readout test, just print the current temp
    counter++;
    if (counter == 10 ) {
      counter = 0;
  EEPROM.write(address, (sumTemp / 10));         //write value to current address counter address
  Serial.print("Sensor value stored at address ");
  Serial.println(address);
  if(address == EEPROM.length())  //check if address counter has reached the end of EEPROM
    address = 0;              //if yes: reset address counter
    sumTemp = 0;
Thanks,Please have a look on codes .Kindly help me to modify this code...
Please take a look at the reference page for the EEPROM library, and the put and get functions
You write only one byte to the EEPROM.
Please help what all changes to be done in code...
