How to write data into SD card?
Hello! im new in Arduino.
im using Arduino duemilanove and MicroSD module and i want to make a program that can read and write data to the SD card…
the program to read the data from SD card already successful but i do not know how to modify the coding so that it also can write data…
here is the coding to read data;
#include <WProgram.h>
#include "mmc.h"
#include "microfat.h"
#define NOT_ENABLED 0
#define READ 1
#define WRITE 2
#define EOL '.'  // used to end the package to write to the board
#define EOF 0  // used to mark end of file
byte buffer[512];
int inByte = -1;
int mode = NOT_ENABLED;
int powerSD = 8;
static unsigned long sector, length;
void setup(void)
  pinMode(powerSD, OUTPUT);
  digitalWrite(powerSD, HIGH);
void loop(void)
  if (Serial.available() > 0) {
    inByte = Serial.read();
    switch (inByte) {
    case 'R':
      mode = READ;
    case 'W':
      mode = WRITE;
    default:
      mode = NOT_ENABLED;
  if (mode == READ)
    mmc::initialize();
    if (microfat::initialize(buffer))
      Serial.println("locate");
      if (microfat::locateFileStart("hola.txt", sector, length))
        Serial.println("read");
        if (RES_OK == mmc::readSectors(buffer, sector, 1))
          if (length > BYTESPERSECTOR)
            length = BYTESPERSECTOR;
          for(int i = 0; i < length; ++i)
            Serial.print(buffer[i], BYTE);
    Serial.println("Done Reading");
    mode = NOT_ENABLED;
Library + example (storing 2 bytes in a temporary buffer and then writing them to the card):
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206874649/8
… and here is a temperature to SD-Card logger (see the last post):
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1257531430/15
