How to write geiger counter code?
Im a beginner . :frowning:
I dont know how to write program wich ll count High states on uC input pin , and later convert it to Counts Per Minute and uSv/h.
I use Atmega 8 with bootloader, 8x2 lcd and STS-5 Geiger tube with High voltage converter.
Tube specs: ( 27 counts per second = 10 uSv/h)
Please Help me with this part of program.
Thats what i have done: (probably all is wrong , but it diplays on lcd number of counts)
 #include <LiquidCrystal.h>
int led = 1;
int inputGM =7;
int inputGMstate = 0;
int counts=0;
unsigned time;
int result;
LiquidCrystal lcd(6, 8, 5, 4, 3, 2);
  pinMode(led, OUTPUT);
  pinMode(inputGM,INPUT);
    lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("COUNTS:");
  time = millis()/1000;
  inputGMstate = digitalRead(inputGM);
  if(inputGMstate == HIGH){
    delay(50);
  counts = counts + 1;
  delay(50);
 result = counts / time * 60;
  lcd.setCursor(0, 1);
  lcd.print(counts);
//led displays one count
  if (counts >= 10){
  digitalWrite(led,HIGH);
{ digitalWrite(led,LOW);
https://sites.google.com/site/diygeigercounter/gm-tubes-supported
Given that you are attaching the LCD to pin 2, why are you writing it LOW at the end of loop()?
Use Tools + Auto Format before posting code again! That mess is too difficult to read.
Remove all the delays, you don't need them and they will give an inaccurate count.
Do not use " time = millis( ) /1000 " it will add nothing and is wrong. Time the interval between two pulses and then work out how many you would get in a minute and display that.
Google "arduino geiger counter" for several examples. Some have code, like this one: http://www.cooking-hacks.com/documentation/tutorials/geiger-counter-arduino-radiation-sensor-board
Cut from this code this what i need , i don’t understand how it works…
 *  ------Geiger Tube board (Arduino Code) Example--------
 *  Explanation: This example shows how to get the signal from the Geiger Tube
 *  in Arduino, we use one of the Arduino interrupt pins (PIN2).
 *  We count the time (ms) between two pulses of the Geiger tube.
 *  Copyright (C) 2011 Libelium Comunicaciones Distribuidas S.L.
 *  http://www.libelium.com
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 2 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
 *  Version:		0.3
 *  Design:		Marcos Yarza, David Gascon
 *  Implementation:	Marcos Yarza
// include the library code:
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(3,4,5,6,7,8);
// Threshold values for the led bar
#define TH1 45
#define TH2 95
#define TH3 200
#define TH4 400
#define TH5 600
// Conversion factor - CPM to uSV/h
#define CONV_FACTOR 0.00812
// Variables
int ledArray [] = {10,11,12,13,9};
int geiger_input = 2;
long count = 0;
long countPerMinute = 0;
long timePrevious = 0;
long timePreviousMeassure = 0;
long time = 0;
long countPrevious = 0;
float radiationValue = 0.0;
void setup(){
  pinMode(geiger_input, INPUT);
  digitalWrite(geiger_input,HIGH);
  for (int i=0;i<5;i++){
    pinMode(ledArray[i],OUTPUT);
  Serial.begin(19200);
  //set up the LCD\'s number of columns and rows:
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Radiation Sensor");
  lcd.setCursor(0,1);
  lcd.print("Board - Arduino");
  lcd.clear();
  lcd.print(" Cooking Hacks");
  lcd.clear();
  lcd.setCursor(0,1);
  lcd.print("www.cooking-hacks.com");
    delay(200);
    lcd.scrollDisplayLeft();
  lcd.clear();
  lcd.print("  - Libelium -");
  lcd.setCursor(0,1);
  lcd.print("www.libelium.com");
  lcd.clear();
  lcd.print("CPM=");
  lcd.setCursor(4,0);
  lcd.print(6*count);
  lcd.setCursor(0,1);
  lcd.print(radiationValue);
  attachInterrupt(0,countPulse,FALLING);
void loop(){
  if (millis()-timePreviousMeassure > 10000){
    countPerMinute = 6*count;
    radiationValue = countPerMinute * CONV_FACTOR;
    timePreviousMeassure = millis();
    Serial.print("cpm = ");
    Serial.print(countPerMinute,DEC);
    Serial.print(" - ");
    Serial.print("uSv/h = ");
    Serial.println(radiationValue,4);
    lcd.clear();
    lcd.print("CPM=");
    lcd.setCursor(4,0);
    lcd.print(countPerMinute);
    lcd.setCursor(0,1);
    lcd.print(radiationValue,4);
    lcd.setCursor(6,1);
    lcd.print(" uSv/h");
    //led var setting
    if(countPerMinute <= TH1) ledVar(0);
    if((countPerMinute <= TH2)&&(countPerMinute>TH1)) ledVar(1);
    if((countPerMinute <= TH3)&&(countPerMinute>TH2)) ledVar(2);
    if((countPerMinute <= TH4)&&(countPerMinute>TH3)) ledVar(3);
    if((countPerMinute <= TH5)&&(countPerMinute>TH4)) ledVar(4);
    if(countPerMinute>TH5) ledVar(5);
    count = 0;
void countPulse(){
  detachInterrupt(0);
  count++;
  while(digitalRead(2)==0){
void ledVar(int value){
  if (value > 0){
    for(int i=0;i<=value;i++){
      digitalWrite(ledArray[i],HIGH);
    for(int i=5;i>value;i--){
      digitalWrite(ledArray[i],LOW);
  else {
    for(int i=5;i>=0;i--){
