How to write into an objet
Good evening,
I am trying to give a value to an objet wihtout success.
I declare it like this:
 struct MyFix {
 //float field1;
   //byte field2;
   char position[FIXSIZE];
Then I create an object
MyFix obj;
But now I would like to give a value to position
char str[]="totototo";
obj.position = str;
Then I print it
Serial.println(fix.position); and it should pirnt:
totototo
My problem is here
obj.position = str;
it does not work and I also tried
obj.position->str;
Which is the good way to attribute a value to an object?
Arrays can't copy themselves: http://arduino.land/FAQ/content/6/30/en/how-to-copy-an-array.html
You could use strncpy
strncpy(obj.position, str, FIXSIZE);
Hello
Thank, yes, it what I just found
http://www.cplusplus.com/reference/cstring/memcpy/
I did like this
memcpy(obj.position,fix,strlen(fix)+1);
But what's the difference between memset and strcpy
I think strcpy() does not add a \0 and the end
You think wrong. The main difference between memcpy() and strcpy() is that strcpy() figures out how much data to copy. You have to tell memcpy().
Thank for this :)
