I'm trying to write to the 0x00 I2C register in the MCP4716 but I'm way lost trying to build the command link because it needs to right/left shift the bits and I don't understand it.
You may even be able to create code to access the MCP4716 via I2C, but I believe that using its library will make the code simpler.
Use the example that comes with the library to test.
(GitHub - jdpetticrew/MCP4716_Arduino: An Arduino Library to control a MCP4716 10bit DAC via i2c.)
I'm using this in ESP-IDF and I've had problems in the past integrating Arduino libraries to it.
It seems simple and I already have all the i2c code to write to it, I'm just missing how to write the packets with the right shift
