Arduino Uno. IDE 2.3.4
ReadAnalogVoltage sketch with modification to get Y axis 0-5
Please may I know how to make Y axis the numbers integers only and no fractions? Right now the trace is all over the place, 4.032, 3.001 and all that. All I want is the integers (example, 0, 1, 2, 3, 4, 5 and not 1.001, 2.33 etc.)
Thank you.
I am writing modified this code
ReadAnalogVoltage
Center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
Dr. G
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1050.0);
// print out the value you read:
Serial.println(voltage);
delay(200); // delay in between reads for stability
