How tom change generator frequency
Hi
How tom change generator frequency using buttons ?
//https://www.i-programmer.info/programming/148-hardware/17804-programming-the-esp32-in-c-pwm-first-example.html?start=4#google_vignette
#include <driver/ledc.h>
int k;
   pinMode(16, INPUT_PULLUP);    //k++
  pinMode(17, INPUT_PULLUP);   //k--
  // Конфигурация таймера
  ledc_timer_config_t timerConfig = {
    .speed_mode = LEDC_LOW_SPEED_MODE,
    .duty_resolution = LEDC_TIMER_10_BIT,
    .timer_num = LEDC_TIMER_0,
    .freq_hz = 10000,              //+++++++++++++++++++++++++++++
    .clk_cfg = LEDC_AUTO_CLK
  ledc_timer_config(&timerConfig);
  ledc_channel_config_t channelConfig1 = {
    .gpio_num = 18,
    .channel = LEDC_CHANNEL_0,
    .timer_sel = LEDC_TIMER_0,
    .duty = 512,
    .hpoint = 0
  ledc_channel_config(&channelConfig1);
  ledc_channel_config_t channelConfig2 = {
    .gpio_num = 19,
    .channel = LEDC_CHANNEL_1,
    .duty = 512,
    .hpoint = 256
  ledc_channel_config(&channelConfig2);
  if (digitalRead(16) == LOW)
    k++;
  if (digitalRead(17) == LOW)
    k--;
  Serial.println(k);
  delay( 100 );
void changeFreq(float freq) {
  if (digitalRead(16) == LOW) {
    k++;
  if (digitalRead(17) == LOW) {
    k--;
  Serial.println(k);
  delay(100);
Use a global variable instead of the fixed 10000. Change the global variable to what you want and call the function again.
I understand what to do but I don't know how.
Sorry to tell you that you actually need to spend some time learning about programming and about the C language.
I did it this way but k doesn't change
int k;
void frequencyChange()  //void somefunc()
// your variable here
    k++;
    k--;
  //++++++++++++++ // put your setup code here, to run once:+++++++++++++++
    .freq_hz = k,              //+++++++++++++++++++++++++++++
  Serial.println(k);
  Serial.println("  k1  ");
    .gpio_num = 18,
    .duty = 512,
    .hpoint = 0
    .gpio_num = 19,
    .duty = 512,
    .hpoint = 256
  Serial.println(k);
  Serial.println("  k2  ");
  delay( 100 );
Tom who? Have you asked him?
Or are you referring to yourself in the 3rd person?
So, why not actually debug the code by printing the values where you actually change based on pin reading values? Debugging means tracking down the source of the problem, not just displaying a final value.
k2 does not change = 0, when pressing the buttons
Why not actually display what value is being read form the buttons, rather than show what subsequent code is producing? Come on, get to the source of the error!!!!
= 0
and this are the readings when buttons are inside void loop()
    k++;
    k--;
Serial.print("  k2 =  ");
  Serial.println(k);
  delay(100);
And what would cause that to happen? Time for a schematic showing the wiring of your switches!
switches are working, k2 is changing when buttons are inside void loop.
*Shows picture of k2 = 0*
*Now shows picture of k2 changing*
It sounds like the setup is identical but obviously it cannot be. What did you change?
Now that you have a variable that changes, what do you think can be done with it?
Variable they should change when they are in
loop, not in
  1. That function would need to be called in order to execute
  2. when the variable changes, it would seem that there would be a need to reconfigure the timer
Perhaps that could help?
If post #16 was directed at me, you need to use Reply.
Just as @camsysca answered you
is never called. WYSIWYG.
Working code = frequency changes
int k;
//const int btn_inc = 16;
//const int btn_dec = 17;
const int maxFreq = 2000;
const int minFreq = 1000;
//unsigned long tim_btn_inc, tim_btn_dec;
// variables will change:
int freq = maxFreq;
int interval = 1; // variables will change:
  int k;
    k++;
    k--;
  Serial.print("  k1 =  ");
  Serial.println(k);
  pinMode(32, INPUT_PULLUP);    //k++
  pinMode(33, INPUT_PULLUP);   //k--
    .gpio_num = 12,
    .duty = 512,
    .hpoint = 0
    .gpio_num = 27,
    .duty = 512,
    .hpoint = 256
  if (digitalRead(32) == LOW) {
    k++;
    if (k >18000) k = 18000;
    // Serial.println(k); //for debugging purposes
  if (digitalRead(33) == LOW) {
    k--;
    if (k < 5000) k = 5000;
    //Serial.println(k); //for debugging purposes
  Serial.print("  k3 =  ");
  Serial.println(k);
  delay( 2 );
When I create separate loop for frequency changing code is not working = no output signal.
int k;
int freq = maxFreq;
  int k;
    k++;
    k--;
  Serial.println(k);
    .gpio_num = 12,
    .duty = 512,
    .hpoint = 0
    .gpio_num = 27,
    .duty = 512,
    .hpoint = 256
    k++;
    if (k > 18000) k = 18000;
    k--;
  Serial.println(k);
  delay( 2 );
