Other option which is maybe easier is to read the reset pin as an analog input and just make sure that the voltage remains above 2.2v
There are other ways still to 'create' more IO pins depending on your application.
Program will be real simple. I have to make 5 or 6 PCBs. I can test the program in advance with a larger arduino, so I really don't need to reprogram the attiny once I programmed it. But thanks for the tip.
