i try to use, two ports in arduino ATmega328p, the first port it control the DFPlayer mini, and the second port, it control Bluetooth module HC-06, but not work, in serial monitor show me this message:
My project Initializing DFPlayer ... (May take 3~5 seconds) Unable to
begin:
1.Please recheck the connection!
2.Please insert the SD card!
but when I delete the Bluetooth code fragment , the project work fine with DFPlayer mini module.
how i would connect two modules, because i try with the sample code of arduino page, but not work for me
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
bool doneFlag = false;
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
/*BLUETOOH*/
SoftwareSerial BT(12,13); // RX, TX
/*BLUETOOH*/
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
# define ACTIVATED LOW
int btnpuerta = 7;
int btnwelcome = 6;
int btnreload = 8;
/*SETUP PARA CADA ACCION EN ARDUINO*/
pinMode(btnpuerta, INPUT);
digitalWrite(btnpuerta,HIGH);
pinMode(btnwelcome, INPUT);
digitalWrite(btnwelcome,HIGH);
pinMode(btnreload, INPUT);
digitalWrite(btnreload,HIGH);
mySoftwareSerial.begin(9600);
/*BLUETOOH*/
BT.begin(9600);
/*BLUETOOH*/
Serial.println(F("Escanmotor.com"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while(true);
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
//----Set volume----
myDFPlayer.volume(30); //Set volume value (0~30).
myDFPlayer.volumeUp(); //Volume Up
myDFPlayer.volumeDown(); //Volume Down
//----Set different EQ----
myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
//----Set device we use SD as default----
myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
//----Read imformation----
Serial.println(myDFPlayer.readState()); //read mp3 state
Serial.println(myDFPlayer.readVolume()); //read current volume
Serial.println(myDFPlayer.readEQ()); //read EQ setting
Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
Serial.println(myDFPlayer.readFileCountsInFolder(3)); //read file counts in folder SD:/03
void loop(){
/*BLUETOOH*/
mySoftwareSerial.listen();
delay(2);
while (mySoftwareSerial.available() > 0) {
char inByte = mySoftwareSerial.read();
Serial.write(inByte);
delay(1);
BT.listen();
delay(2);
while (BT.available() > 0) {
char inByte = BT.read();
delay(1);
/*BLUETOOH*/
if (digitalRead(btnpuerta) == ACTIVATED) {
myDFPlayer.play(1);
delay(2500);
if (digitalRead(btnwelcome) == ACTIVATED) {
if (doneFlag == false) // fragmento para repetir el comando una sola vez
myDFPlayer.play (5);
delay (2000);
myDFPlayer.stop ();
doneFlag = true;
if (digitalRead(btnreload) == ACTIVATED) {
doneFlag == true;
void printDetail(uint8_t type, int value){
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
case WrongStack:
Serial.println(F("Stack Wrong!"));
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
case DFPlayerUSBInserted:
Serial.println("USB Inserted!");
case DFPlayerUSBRemoved:
Serial.println("USB Removed!");
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
case Sleeping:
Serial.println(F("Sleeping"));
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
case FileMismatch:
Serial.println(F("Cannot Find File"));
case Advertise:
Serial.println(F("In Advertise"));
default:
default:
