How we can program using software serial for above output chart
Welcome to the forum
You started a topic in the Uncategorised category of the forum whose description is
DO NOT CREATE TOPICS IN THIS CATEGORY ![]()
Your topic has been moved to a more pertinent category
1. Let us assume the following arbitrary values for the data items of your given chart:
Byte-1: 1 1 1 1 1000 (0xF4)
Byte-2: 0 1010100 (0x54)
Byte-3: 0 1 0 0 0110 (0x46)
Byte-4: 0 1001001 (0x49)
Byte-5: 0 1010101 (0x55)
Byte-6: 0 0110110 (0x36)
Byte-7: 0 0111011 (0x3B)
2. Transmission Frame:
Frame synchronization pattern: 0x123456
Data: 7-byte natural bnary of Step-2
3. At the receiver, look for the sync pattern 0x123456 and then receive all 7-byte data.
4. For data validity, extract the all sync bits from the received bytes and chcek their values.
5. If Step-4 is alright, then extract the SpO2 and Temperature data.
Hello sworldtechnologies
Welcome to the world's best Arduino forum ever.
Consider this data transmitter to get started:
uint8_t sensor[] {B00110000,B00110001,B00110010,B00110011,B00110100,B00110101,B00110110};
constexpr uint8_t sizeArray {sizeof(sensor)};
Serial.write(sensor, sizeArray);
Do you want to send data in that format or receive it and parse it ?
Which Arduino board are you using ?
Only receiving data. board using Nano
Thank you.. GolamMostafa
Thank you paulpaulson
