how when the push button is pressed the timer starts?
when the push button is pressed the timer starts? and timers that have been set to work. when the timer off the system will return to the initial conditions.
#include <LiquidCrystal.h>
int hours = 0 ; // start hours
int minutes = 2 ; //start min
int seconds = 0; //start seconds
//LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //<--removed- Different LCD manufacture
LiquidCrystal lcd(7, 6, 5, 4, 3, 2);//Pin Code for Arduino SainSmart LCD 1602 KeyPad
lcd.begin(16, 2);
lcd.print("Count Down Timer ");
// lcd.scrollDisplayLeft();
// wait a bit:
delay(150);
while (hours > 0 || minutes > 0 || seconds >= 0) {
lcd.setCursor(4, 2);
(hours < 10) ? lcd.print("0") : NULL;
lcd.print(hours);
lcd.print(":");
(minutes < 10) ? lcd.print("0") : NULL;
lcd.print(minutes);
lcd.print(":");
(seconds < 10) ? lcd.print("0") : NULL;
lcd.print(seconds);
lcd.display();
stepDown();
void stepDown()
if (seconds > 0) {
seconds -= 1;
if (minutes > 0) {
seconds = 59;
minutes -= 1;
if (hours > 0) {
seconds = 59;
minutes = 59;
hours -= 1;
trigger();
void trigger() {
lcd.clear(); // clears the screen and buffer
lcd.setCursor(5, 1); // set timer position on lcd for end.
lcd.println("OFF");
lcd.display();
