Hey all,
I recently noticed the lack of an upload speed setting in the 2.0 IDE and I was wondering whether there even was one. It doesn't seem to be under "Tools" much like previous versions, so where could it be?
Thanks in advance.
Hey all,
Thanks in advance.
Do you have the correct board selected? Most do not have that option, the only one I recall seeing it on was for the ESP8266.
I'm currently troubleshooting an ESP32 and saw that changing the upload speed might solve the issue from this video which as far as I can see can change the upload speed for the ESP32. Though, the individual's ESP32 seems to be named rather unconventionally, so they may have a modified board and that's why they have the option
Hi @yakh. Thanks for giving the Arduino IDE 2.0.0 release candidate a try!
Which board do you have selected from the Tools > Board menu in the Arduino IDE?
The Tools > Upload Speed menus is added only when specific boards are selected. From a quick look, I see that most of the ESP32 boards have it, but I noticed one or two where it was not set up by the person who added the board definition.
Which version of the ESP32 boards platform are you using?
How did you install it? Was it done via Boards Manager, or did you use the git clone method?
I believe I installed the latest version (1.06) and yes, I did indeed install it via the Boards Manager by adding: https://dl.espressif.com/dl/package_esp32_index.json
to "Additional Board Manager URLs". I'm currently using this board, which I've been told is an off-brand AI-Thinker, so I selected that as my board both in the board manager and in the example code I'm attempting to run. I am, unfortunately, running into issues uploading the code to the board and since I've been told that changing my upload speed to something faster may help, I've been looking for a way to do that with the excellent 2.0 IDE.
You are almost a year out of date. The latest version is 2.0.2.
That is the reason you are out of date. They changed the URL and are no longer updating the old one. The new URL is provided in the official documentation here:
You can follow these instructions to update to 2.0.2:
That happens to be one of the few boards that does not have an "Upload Speed" menu:
Ah, this is rather unfortunate news . I had been following this tutorial and its attached installation guide for the library that was rather outdated! Though, the most recent update I can select in both the dev and stable releases is 1.8.5. Thank you for the help!
You are welcome. I'm glad if I was able to be of assistance.
I recommend double checking that you clicked on "ESP32 Arduino by Espressif Systems" in Boards Manager. That boards platform never had a 1.8.5 release. However, that is the latest release of the "Arduino AVR Boards" platform, which makes me think you might have been looking at it instead.
Yet again I mess up . Apologies, I've just now corrected my mistake and installed the correct library. Thank you for your help and your patience!
