I've used TI75441 h-bridges on other projects, but am unsure how I'd wire the 4-pin one above. Does anyone know how I'd wire it, or if there's another 3v h-bridge I should use?
That IC will not drive a motor from an arduino. It will drive a motor when you put a magnet on it. The direction of the magnet determines the motor's direction.
I don't think that is what you want to do is it?
Definitely not what I'm looking to do! I'm looking to drive a 3V DC motor using an arduino pro mini with 3V logic. So I need a 3V h-bridge, but haven't been able to find one.
Do you need to go both directions? If not you can use a transistor. If so you can take 2 NPN and 2 PNP transistors and make an h-bridge of your own as big or small as you want.
