how would you use a reverse button with this code
so I found this code on the internet, and i'm wondering if you can use a reverse button with it.
i.e: button unpressed = button pressed button pressed = button unpressed.
here's the code
pinMode(2, INPUT_PULLUP);// define pin two as input for push button
pinMode(10, OUTPUT);// defind pin 10 as output
int pusshed = digitalRead(2);// read pin 2 and put the result in the "pusshed" variable
if(pusshed == LOW){
digitalWrite(10, HIGH);// if pusheed is equal LOW, turn the pin 10 HIGH (give it 5v)
}else{
digitalWrite(10, LOW);// else set pin 10 to low or zero volt
“ button unpressed = button pressed button pressed = button unpressed.”
Say what ? :o
if(pusshed == LOW){
VS
if(pusshed == HIGH){
How do you have ‘your’ switch wired ?
The button is a computer case intrusion button, that’s why its reversed
nsent, would seem possible to just swap the digital Writes
}else{
i had to change the if(pusshed == LOW too if(pusshed == HIGH
Hmmm, I would write:
digitalWrite(10, ! digitalRead(2));
Using it as a power button for my pc that has no case, it works fine now!
