Howe can I get a button to start a RF 433MHz transmitter to send a message?
I have a pair of this cheep 433 mhz transmitter/reciver. I have make a cod so the sending and reciving works good.
I want to make it as a remote control. So when a switch is acivated i vant a message to be sent .
But I can’t figure it out howe to do that.
//Reciver
#include <VirtualWire.h>
#undef int
#undef abs
#undef double
#undef float
#undef round
  Serial.begin(9600); //debygging endast
  Serial.println("setup");
  vw_set_rx_pin(7);
  vw_setup(2000);
  vw_rx_start();
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen))
    int i;
    digitalWrite(12, true);
    Serial.print("GOT: ");
    for (i = 0; i < buflen; i++)
      Serial.print(buf[i], HEX);
      Serial.print("  ");
    Serial.println(" ");
    digitalWrite(12, false);
//Transmitter
#undef int
#undef abs
#undef double
#undef float
#undef round
  Serial.begin(9600); // debugging endast
  vw_set_tx_pin (7);
  vw_setup(2000);
  const char *msg = "Hello";
  digitalWrite(13,true); //tänder Led för att visa sändning
  vw_send((uint8_t *)msg,strlen(msg));
  vw_wait_tx();
  digitalWrite(13, false);
  delay(200);
If anyone have a tip to give me i would be glad.
Bertil
Do you really mean remote control or do you mean a wired switch or button ?
Hello
I made a complete tutorial about this kits in my blog
controlrobotics.rodrigomompo.com
If you're kit is already working, you just see Part 4 of the tutorial. In my case I used a jostick for controling a robot car.
Good Luck
Ok I will check your blog.
I mean a wired button.
Thanks
Bertil
How is it wired? Where are you reading the state of the switch? Wiring a button to the Arduino may prove useless. Put the button back on the shirt, and use a switch. Much more reliable.
Router 45 I wounder about this lines in your code
 // Turn on a light to show transmitting
 vw_send((uint8_t *)Sensor1CharMsg, strlen(Sensor1CharMsg));
 vw_wait_tx(); // Wait until the whole message is gone
 // Turn off a light after transmission
 delay(40);
I missing what is the code for tourn on and of the light?
Berti
This is a mistake in the code
the code for turning on the light doesn't exit. Just ignore the coments about the led.
svarven: void loop() {   const char *msg = "Hello";   digitalWrite(13,true); //tänder Led för att visa sändning   vw_send((uint8_t *)msg,strlen(msg));   vw_wait_tx();   digitalWrite(13, false);   delay(200); }
Bertil
Change loop() like this and define the new global variables before setup()
    readButton();
    sendMessage();
void readButton() {
   if (digitalRead(buttonPin) == LOW) {
       buttonPressed = true;
void sendMessage() {
  if (buttonPressed == false) {
     return;
  vw_wait_tx();
   buttonPressed = false;
  delay(200);
...R
