Hi all!
As I have posted before, I've been working on a new Modbus library. The fact is that it still needs to append the HardwareSerial inside it. At this moment, it is just outside the class declaration:
HardwareSerial port = Serial; ///< Pointer to Serial class object
/* _____CLASS DEFINITIONS____________________________________________________ */
* Arduino class library for communicating with Modbus devices over
* RS232/485 (via RTU protocol).
class Modbus {
private:
uint8_t u8id; // 0=master, 1..247=slave number
uint8_t u8serno; // serial port: 0-Serial, 1..3-Serial1..Serial3
uint8_t u8txenpin; // 0=USB or RS-232 mode, >0=RS-485 mode
uint8_t u8state;
uint8_t au8Buffer[MAX_BUFFER];
uint8_t u8BufferSize;
uint8_t u8lastRec;
uint16_t *au16regs;
uint16_t u16InCnt, u16OutCnt, u16errCnt;
uint16_t u16timeOut;
uint32_t u32time, u32timeOut;
uint8_t u8regsize;
void init(uint8_t u8id, uint8_t u8serno, uint8_t u8txenpin);
void sendTxBuffer(); // transmit buffer to serial port
int8_t getRxBuffer(); // get serial buffer contents
uint16_t calcCRC(uint8_t u8length); // get CRC from au8Buffer until u8length
uint8_t validateAnswer();
uint8_t validateRequest(); // validate master request
void get_FC1(); // *** only master ***
void get_FC3(); // *** only master ***
int8_t process_FC1( uint16_t *regs, uint8_t u8size ); // *** only slave ***
int8_t process_FC3( uint16_t *regs, uint8_t u8size ); // *** only slave ***
int8_t process_FC5( uint16_t *regs, uint8_t u8size ); // *** only slave ***
int8_t process_FC6( uint16_t *regs, uint8_t u8size ); // *** only slave ***
int8_t process_FC15( uint16_t *regs, uint8_t u8size ); // *** only slave ***
int8_t process_FC16( uint16_t *regs, uint8_t u8size ); // *** only slave ***
void buildException( uint8_t u8exception ); // build exception message
public:
Modbus();
Modbus(uint8_t u8id, uint8_t u8serno);
Modbus(uint8_t u8id, uint8_t u8serno, uint8_t u8txenpin);
void begin(long u32speed);
void begin();
void setTimeOut( uint16_t u16timeout); // only for master
uint16_t getTimeOut(); // only for master
int8_t query( modbus_t telegram ); // only for master
int8_t poll(); // cyclic poll for master
int8_t poll( uint16_t *regs, uint8_t u8size ); // cyclic poll for slave
uint16_t getInCnt(); // number of incoming messages
uint16_t getOutCnt(); // number of outcoming messages
uint16_t getErrCnt(); // error counter
uint8_t getID();
uint8_t getState();
Whenever more than one object is declared, the processor stops working. I'm afraid that all these objects are using the same "port" variable.
How can I implement HardwareSerial inside my class?
Best Regards,
