HP206c Grove Sensor + Arduino MKR GSM 1400
Hi everyone,
I planned to use a pressure sensor (Grove - HP206c) and upload data by an Aurduino MRK GSM 1400.
To make the project uploadable I installed also an Arduino MKR Connector Carrier.
Just to try the sensor I opened the example sketch HP20x demo made by Oliver Wang from Seeed Studio.
If I compile the sketch it return an error and doesn't work.
I tried to exclude one library at time and the error occurs when <HP20x_dev.h> or <KalmanFilter.h> are called.
I think everyone of you could try and will have the same problem.
The error is:
Arduino:1.8.12 (Windows 8.1), Board:"Arduino MKR GSM 1400"
C:...\Arduino\libraries\Grove_barometer_HP20x\HP20x_dev.cpp: In constructor 'HP20x_dev::HP20x_dev()':
C:...\Arduino\libraries\Grove_barometer_HP20x\HP20x_dev.cpp:33:22: error: no matching function for call to 'TwoWire::TwoWire()'
In file included from C:...\Arduino\libraries\Grove_barometer_HP20x\HP20x_dev.h:14:0,
from C:...\Arduino\libraries\Grove_barometer_HP20x\HP20x_dev.cpp:13:
C:...\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.6\libraries\Wire/Wire.h:35:5: note: candidate: TwoWire::TwoWire(SERCOM*, uint8_t, uint8_t)
TwoWire(SERCOM *s, uint8_t pinSDA, uint8_t pinSCL);
C:...\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.6\libraries\Wire/Wire.h:35:5: note: candidate expects 3 arguments, 0 provided
C:...\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.6\libraries\Wire/Wire.h:32:7: note: candidate: constexpr TwoWire::TwoWire(const TwoWire&)
class TwoWire : public Stream
C:...\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.6\libraries\Wire/Wire.h:32:7: note: candidate expects 1 argument, 0 provided
C:...\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.6\libraries\Wire/Wire.h:32:7: note: candidate: constexpr TwoWire::TwoWire(TwoWire&&)
exit status 1
Error during compiling for board Arduino MKR GSM 1400.
How to solve it?
Thank you in advance
